Topic: Foobar usage on a tactile PC - Tap vs. double-tap (Read 154 times) previous topic - next topic
I'm considering using foobar on a tactile Windows PC, and I have a "tactile noob" question :
Is there a way to play a song by simply tapping on it once in a given playlist component (Playlist View, EsPlaylist, etc.), instead of having to double-tap on it to emulate a double-click ?
I don't know if that kind of setting must be handled by foobar, by Windows, or by some 3rd-party component.
Thanks !
Re: Foobar usage on a tactile PC - Tap vs. double-tap
ELplaylist (note EL, not ES) can configure click actions and assign to various items (play, pause, next track, edit,.....).
Thank you. I'll have to check it out, definitely. I guess you're talking about this one ? https://hydrogenaud.io/index.php/topic,62133.0.html
Also, it looks like a CUI component. Can it run under DUI ?
Otherwise, maybe Windows 10 tactile actions can handle / let user define single clicks, double clicks, gestures and so ? I don't know much about it yet, so any doc would be welcome.
No, sorry it's columns ui only. I should have mentioned that.
