Topic: Masstagger: how to include space (Read 1232 times) previous topic - next topic
how to take a space into account when renaming, the fact is that when I rename
$replace((%title%),Feat.,feat.
the second point is reached, I consider it a way to use a space, but the masteragger does not take it into account
$replace((%title%),Feat. ,feat. ,
I read this topic, it seems like a similar situation, but I did not find a solution, either surrounded by apostrophes
https://hydrogenaud.io/index.php?topic=56362.msg506262#msg506262
Re: Masstagger: how to include space
Wrap the entire parameter in single quotes / apostrophes. You have to wrap literal parentheses too.
$replace('('%title%')','Feat. ','feat. ')
$replace($replace($replace($caps2(%title%), ,  ,'[','('), A , a , An , an , The , the , And , and , But , but , Or , or , Nor , nor , At , at , By , by , For , for , From , from , In , in , Into , into , Of , of , Off , off , On , on , Onto , onto , Out , out , Over , over , To , to , Unto , unto , Up , up , With , with , As , as , Feat,feat,Feat,feat.,ft.,feat.,ft,feat.,Featuring,feat.,Vs,vs,DJ,Dj,remix,Remix,–,-,—,-,hidden,Hidden,track,Track,remix,Remix,bonus,Bonus,part,Part,acoustic,Acoustic,version,Version),  , )
I apologize for the inaccurate question. I have this line, here surround apostrophes only commas near ','Feat. ','feat. ' so that another renaming does not break
(Name (feat. Test))
this option brackets the whole name of the song, but I just wanted to change the capitalization
$replace((%title%),'Feat. ','feat. ') dont work, help
You can't use the parentheses in that parameter, they're special characters that need to be quoted. Using parentheses on the parameter will not make it selectively operate on the parentheses of the string. This requires more complex parsing than simple quoting can do.
