Topic: DSF to WAV conversion (Read 185 times) previous topic - next topic
     Earlier this year I bought a Sony Hi-Res turntable. I needed to find a program that would convert these files to wav. I got on the Steve Hoffman forum and did some research, and learned about Foobar2000. I downloaded the app and a plugin that would make Foobar capable to convert the DSF files to wav. For several months I was successfully and happily converting the files with absolutely no issues until the end of this year, when it just suddenly stopped being able to recognize the files. So I uninstalled Foobar, shut the computer down, started it up again, went to Foobar's web site, reinstalled the program from their site (not from an outside source), downloaded the components that I would need (following the directions for doing so from Foobar's web site), shut down the program, opened it again, and tried to convert a DSF file...no way! It doesn't recognize the files. What happened? What am I doing wrong?
Re: DSF to WAV conversion
Hi there,
Which ones? Have you got foo_input_sacd (SACD Decoder) component? (This is not listed on foobar component website)
What error message did you get? Which foobar version and OS?
Cheers
     Hi, thanks for the reply. I'm sorry for not being completely clear in my earlier post. Yes, I downloaded the SACD plug in using a link from a forum on the Steve Hoffman web site. Yesterday (the 1st), I opened it, and this time around...it worked! However, when I'm converting a DSF file to WAV, I'm getting a box that tells me that (I can't remember specifically) in essence the conversion will not be a lossless conversion. I'm converting from DSF to a 32 bit WAV file. I never used to get that message when converting. But it seems to me that a WAV file is lossless in any event. Is that a correct assumption? I converted a DSF file that had already been converted to WAV at an earlier time after realizing that this message was appearing, and all the specifics were the same; the file size, bit rate, ect. There seemed to me to be no change.
