Topic: Need help with Nero aac encoder in latest Foobar2000 (Read 583 times) previous topic - next topic
In the new version of foobar2000, the Nero aac encoder is not present in the conversion function presets. I kindly wanted to know which string I should manually enter in the custom preset window, for convert from audio cd. Sorry for my english.
Thanks again
Re: Need help with Nero aac encoder in latest Foobar2000
That encoder is not included in Foobar's encoder pack download, so you need to download it manually and put it in the "encoders" sub-directory (suggested), then create your own custom preset (Quick Convert/Add New/drop down to Custom and create your preset params).  Download location and command line usage is here:  https://wiki.hydrogenaud.io/index.php?title=Nero_AAC
Nero encoder is still supported by the Converter and it has built-in support for it. Just create a new preset and you can pick Nero from the encoder list.
Case: I had assumed (that deadly word!) that the only encoders available were the ones provided by the Free Encoder Pack;  I didn't realize there were also built-in capabilities and I appreciate you setting me straight on that!  Thanks.
Thanks Case, I made a mistake.
