convert a portable version of foobar in install version 2019-11-30 22:46:03 Hi, I want to convert a portable version downloaded on some forum to a fix version installed to use foobarcon....So i installed a normal version and copy all the portable version folder in /appdata/roaming/foobar folder...except he small portable mode file, but I'm sure I don't need to copy all...I want to know if I need to copy some files in programm files/foobar and which one, and those to be copied in roaming folder......thank's..here the actual files and folder i keep in roaming....
Re: convert a portable version of foobar in install version Reply #1 – 2019-11-30 22:52:17 The two directories components and encoders should be kept in the install dir, not in the profile dir under roaming. Same with the three *.dll files.
Re: convert a portable version of foobar in install version Reply #2 – 2019-12-01 15:17:21 can I send you the last portable version of foobar updated and say me what files to copy onprogram files and others to roaming...thank you..
