how extract music files from apk files 2019-11-30 06:23:32 i need to rip the ost from dbz dokkan battle (a movile game) but idk how..
Re: how extract music files from apk files Reply #1 – 2019-11-30 13:17:45 You can extract an apk with any unzip program (i used 7zip).In dragon-ball-z-dokkan-battle-4-5-3.apk I only found one music file called bgm_009.awb in assets\bgm\.Install foobar2000 and install the the vgmstream decoder by Kode54.Then you should be able to play the bgm_009.awb file.According to foobar/vgmstream it is this format: CRI ADX 4-bit ADPCM (type 9 encryption).I do not know the game, but i suspect there should be more music than this one. So either i missed it in the apk.Or maybe the game download additional data file. Then you should search that.
Re: how extract music files from apk files Reply #2 – 2019-11-30 19:37:38 wrong forum, instead try here:https://zenhax.com/
Re: how extract music files from apk files Reply #3 – 2019-12-01 02:53:18 Quote from: Mark7 on 2019-11-30 13:17:45You can extract an apk with any unzip program (i used 7zip).In dragon-ball-z-dokkan-battle-4-5-3.apk I only found one music file called bgm_009.awb in assets\bgm\.Install foobar2000 and install the the vgmstream decoder by Kode54.Then you should be able to play the bgm_009.awb file.According to foobar/vgmstream it is this format: CRI ADX 4-bit ADPCM (type 9 encryption).I do not know the game, but i suspect there should be more music than this one. So either i missed it in the apk.Or maybe the game download additional data file. Then you should search that.yeah i dont know if the sound files are getting by actualization or if i need to install the game in my phone and then seach the files
Re: how extract music files from apk files Reply #4 – 2019-12-02 10:10:29 According to Wikipedia, ADX is a variant of MPEG2 audio. So mpg123 should be able to play the demuxed stream. But it says the file is encrypted and without a (legal) key, your are out of luck. Probably easier to grab the analog signal with an ADC.
Re: how extract music files from apk files Reply #5 – 2019-12-03 05:37:11 ADX is an ADPCM format owned by CRI Middleware, not an mpeg derivative.
Re: how extract music files from apk files Reply #6 – 2019-12-03 12:36:13 Quote from: kode54 on 2019-12-03 05:37:11ADX is an ADPCM format owned by CRI Middleware, not an mpeg derivative.My mistake, the MPEG2 audio derivative is AHX.
Re: how extract music files from apk files Reply #7 – 2019-12-03 15:28:34 Quote from: tehabe on 2019-12-02 10:10:29According to Wikipedia, ADX is a variant of MPEG2 audio. So mpg123 should be able to play the demuxed stream. But it says the file is encrypted and without a (legal) key, your are out of luck. Probably easier to grab the analog signal with an ADC.how i can get the files then? i dont know how to grab the signal with adc
Re: how extract music files from apk files Reply #8 – 2019-12-03 20:01:45 Quote from: tiffaff on 2019-12-03 15:28:34how i can get the files then? i dont know how to grab the signal with adcUse Apktool to properly decode *.apk then QuickBMS with the appropriate scripts (*.awb/*.cpk/...).If despite all that you don't succed, ask on ZenHAX.
Re: how extract music files from apk files Reply #9 – 2019-12-04 08:00:08 Quote from: Thundik81 on 2019-12-03 20:01:45If despite all that you don't succed, ask on ZenHAX.they didnt answer mewell i will try for my own... but if someone can help me it will be great too
Re: how extract music files from apk files Reply #10 – 2019-12-04 10:34:53 Quote from: tiffaff on 2019-12-04 08:00:08they didnt answer mewell i will try for my own... but if someone can help me it will be great tooYou posted in the wrong section, didn't provide any useful information (url, not a single awb file) and despite this you got an answer.Did you even try extracting the awb files with QuickBMS with the proper script?
Re: how extract music files from apk files Reply #11 – 2019-12-04 22:48:34 Quote from: Thundik81 on 2019-12-04 10:34:53Quote from: tiffaff on 2019-12-04 08:00:08they didnt answer mewell i will try for my own... but if someone can help me it will be great tooYou posted in the wrong section, didn't provide any useful information (url, not a single awb file) and despite this you got an answer.Did you even try extracting the awb files with QuickBMS with the proper script?i tried but idk how
Re: how extract music files from apk files Reply #12 – 2019-12-05 08:06:41 can make a request? i only needs 3 themes from this gamekid goku themetitle themetitle 8 bit theme
Re: how extract music files from apk files Reply #13 – 2019-12-06 18:59:32 Downloading the music from youtube is probably an easier way.https://m.youtube.com/watch?v=2ppMBeOcrZs
Re: how extract music files from apk files Reply #14 – 2019-12-07 06:12:08 Yes, but that file at least have 3 re-encoding, i want it in his true quality
