Topic: convert a SACD to flac. (Read 514 times) previous topic - next topic
I like to convert a SACD to flac.
I have two ISO  SACD images.
When i open the ISO in Fb2 it shows 24 files. There are only 12 files on the first ISO according to info. What do i do wrong?  ::)
These extra 12 files are duplicates of the first 12.
Re: convert a SACD to flac.
Probably because there are stereo tracks and multichannel variants of the same tracks.
Have you tried running the conversion? My guess is that 12 tracks will convert and 12 will fail.
how do i resolve that ?
By looking at Properties of tracks. In playlist right click on track, then select Properties.
The SACD plugin can sometimes display two sets of tracks in a given ISO, if the ISO contains both stereo and surround mixes. As for track lengths, if you convert DSD to PCM, it needs to overlap the original cue points slightly to make the track ends line up. Of course, technically, it should be internally decoding the overlaps and then cutting them back off again when producing the output.
(The reason for this is because DSD is a delta encoding format, and being only a single bit of precision, must always start at a volume offset at the center of the waveform. To line up the track start to an approximation of the previous track's end, it needs to start decoding maybe ten seconds early, then discard the first ten seconds of resampled output. This should produce a fair approximation for gapless playback.)
Yes,
Stereo 2 channel and 5.1 channel.
I suppose there is no benefit to use 5.1 channel music files in a 2 channel stereo system. I want a 24Bit stereo file for my NAS station.
Artist Le Concert des Nations direction Jordi Savall
Title Ouverture (Suite) I en ut majeur   BWV 1066 - (Ouverture)
Album Les Quatre Ouvertures - Suites pour orchestre BWV 1066 - BWV 1069
Track 6/12
Disc 1/2
Genre Classical
Year 2012
Rating
Composer Johann Sebastian Bach
Size 107,88 MB  (34% Compressed)
Original Size 162 MB
Length 10 minutes 42 seconds
Channels 2  (stereo)
Sample Rate 44,1 KHz;
Sample Size 24 bit
Bit Rate 2 116 kbps  (DVD)
Encoder FLAC reference libFLAC 1.3.1 20141125
Encoder Settings
Audio Quality Perfect (Lossless)
Contains CRC, ReplayGain, ID Tag [Vorbis Comments]
Channel Mapping
File A_Ouverture (Suite) I en ut majeur   BWV 1066 - (Ouverture)
Type FLAC Audio    [.flac]
_______________________________________________________________________________________________________________________
Track 6/12
Disc 1/2
Genre Classical
Year 2012
Rating
Size 256,32 MB  (37% Compressed)
Original Size 405,01 MB
Channels 5  (surround)
Sample Size 24 bit
Bit Rate 5 292 kbps  (DVD)
Encoder Settings
Channel Mapping
File Ouverture (Suite) I en ut majeur   BWV 1066 - (Ouverture)
If you plan to do more of these, you might want to add a "Channels" column to your foobar2000 playlist window so you can more easily pick out the "stereo" files vs. multi-channel.  The column pattern is [%channels%]
