Topic: .CUE & .FLAC, .WV, WAV & APE duplicate files on Playlist (Read 380 times) previous topic - next topic
Hello everyone! This is my first post and is a question about foobar2000 and how to show properly my files on Playlist.
Foobar2000 v1.4.8
My components installed:
Core (2019-09-21 07:57:28 UTC)
    foobar2000 core 1.4.8
foo_albumlist.dll (2019-09-21 07:56:52 UTC)
    Album List 4.6
foo_bpm.dll (2019-05-20 14:24:26 UTC)
    BPM Analyser 0.2.4.6
foo_cdda.dll (2019-09-21 07:56:50 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2019-09-21 07:56:52 UTC)
    Converter 1.5.3
foo_cuefixer.dll (2019-11-22 17:52:22 UTC)
    CUE fixer 1.0
foo_dsp_eq.dll (2019-09-21 07:56:44 UTC)
    Equalizer 1.2.1
foo_dsp_std.dll (2019-09-21 07:56:48 UTC)
    Standard DSP Array 1.3.2
foo_dynamic_range.dll (2019-05-04 20:47:15 UTC)
    Dynamic Range Meter 1.1.1
foo_facets.dll (2019-11-22 14:40:28 UTC)
    Facets 1.0
foo_fileops.dll (2019-09-21 07:56:48 UTC)
    File Operations 2.3
foo_freedb2.dll (2019-06-28 18:42:26 UTC)
    Online Tagger 0.7
foo_input_monkey.dll (2019-08-31 23:13:36 UTC)
    Monkey's Audio Decoder 2.3
foo_input_std.dll (2019-09-21 07:57:14 UTC)
    FFmpeg Decoders 3.4.5
    Standard Input Array 1.4.8
foo_playcount.dll (2019-03-07 19:45:28 UTC)
    Playback Statistics 3.0.3
foo_plorg.dll (2015-10-13 16:24:46 UTC)
    Playlist Organizer 2.6
foo_rgscan.dll (2019-09-21 07:56:56 UTC)
    ReplayGain Scanner 2.3
foo_simplaylist.dll (2019-11-22 16:18:27 UTC)
    SimPlaylist 1.0
foo_ui_std.dll (2019-09-21 07:57:10 UTC)
    Default User Interface 1.4.8
foo_uie_vis_channel_spectrum.dll (2008-05-18 09:02:12 UTC)
    Channel Spectrum panel 0.17.2
foo_uie_vis_peakmeter_spectrum.dll (2010-03-07 17:24:47 UTC)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_unpack.dll (2019-09-21 07:56:56 UTC)
    ZIP/GZIP/RAR Reader 1.8
foo_vis_vumeter.dll (2013-02-16 17:44:26 UTC)
    VU Meter 2013-02-16
I've installed foo_cuefixer but doesn't work.
Disabled/removed: *.CUE on
Preferences -> Media Library --> Exclude [Empty field]
Preferences -> Shell Integration -> Exclude file types [Empty Field]
added one screenshot for show in details my problem.
Thanks and i hope someone can help me  :))
Re: .CUE & .FLAC, .WV, WAV & APE duplicate files on Playlist
One solution to this is to manually embed .cue to single .flac file
To do this:
1. Add *.cue to exclude in Album List
2. I would recommend to remove tags from .flac file first. Right click on .flac file in foobar > Tagging > Remove tags from file
3. Right click on .flac file in foobar > Utilities > Edit cuesheet > Load > Ok
By default edit cuesheet option is not listed in utilities but you can enable it by holding shift button then do right click or you can enable it in Preferences > Display > Context Menu > Utilities
foobar2000 plays music
To do this:
Thanks for the tip, this seems a good option, but currently i have almost 2.5TB from music in FLAC, WAV, WV & APE (file+cue).
There's any other option?
Hi there,
Well you have the Facets filter button there, you could use that to show only CUE files. Example, click the filter button down arrow and Preferences > Add New button -
"$stricmp($ext(%filename_ext%),cue)" PRESENT
"$stricmp($ext(%filename_ext%),cue)" MISSING
Likewise you could use the Facets columns as a filter to show only CUE. This way alone with the filter button off, would still show media files when typing for search results on the playlist, until you select something from the columns. Example, in Preferences > Media Library > Facets -
$if($stricmp($ext(%filename_ext%),cue),%<artist>%,)
(Etc, for the other columns)
Otherwise, you could simply exclude all the media file types from the library, in Preferences > Media Library > Restrict to: *.CUE. If you have the opposite in Preferences > Shell Integration > Exclude: *.CUE, you could still drop a folder from Windows Explorer to edit media file tags.
Cheers
