Topic: TAC Taudio Converter portable (Read 546 times) previous topic - next topic
Hello everyone,
TaudioConverter does not work, i.e. after extracting the audio track in wave format, it changes the screen to the encoding screen and freezes. this happens with various versions. I've downloaded several but all the same story.
What should I do?
Re: TAC Taudio Converter portable
What should I do?
Try a different application.   :P
You're converting to WAV?   From what?
What should I do?
I converted an audio cd to .m4a, but the program got stuck in the initial conversion phase. It was just to see if it was something that happens only to me or it's just the program. It has a nice interface and 'so I was trying it.
I've never had it freeze.  On some computers I get a "missing DLL" message, but I just click "OK" and then it runs fine.
I've never tried ripping with TAudioConverter.   I currently use EAC or CUERipper.
OK I'll bite.
Grabbed 0.9.9 build 3899 64bit portable
I get a missing bass.dll error at 1st start attempt but starts 2nd try (no bass.dll on my system, just the one in the program subfolder)
Rip CD and convert using FDKAAC
initial error: Cover art downloader error code: 2; Error message: Couldn't find image
rip completed successfully
conversion completed successfully
copied required AppleApplicationSupport files to QAAC subfolder
Rip CD and convert using QAAC
copied required DLLs to fhgaacenc subfolder
Rip CD and convert using FHGAAC
korth
OK I'll bite.
I'll try and let you know. Thank you so much.  in the subfolder there is one with that name, where then there are all the dlls that is bass.ac3.ddl and so on
encoders are in \Tools
korth
