FAAC aac encoder 2019-11-18 20:55:25 Good evening ,with exact audio copy, which command line parameters I need to enter to encode an audio cd with the faac encoder 1.29?Thank you all
Re: FAAC aac encoder Reply #2 – 2019-11-18 22:07:46 Quote from: m14u on 2019-11-18 21:54:42encodername.exe --helpI'm trying but it's not working Last Edit: 2019-11-18 22:10:38 by pompelmorosa
Re: FAAC aac encoder Reply #3 – 2019-11-19 16:48:02 Start by showing what you tried so far that isn't working. You should be able to work most of this out by yourself.I would start with the General Configuration for Encode AAC from the EAC and QAAC page in the Hydrogenaudio Knowledgebase.http://wiki.hydrogenaud.io/index.php?title=EAC_and_QAAC#General_Configuration_for_Encode_AACuse the path to the faac.exe encoderLook at the encoder usage for the options. As suggested by m14u the encoder usage information can usually be found using encodername.exe --help from the command prompt while in the source directory. You would use faac.exe --helpOr you can search google for usage informationhttps://www.mankier.com/1/faacsays to use -o <filename> for the output (That's the same option QAAC uses. You'll note most of the tagging options are the same too except a few like --disc instead of --disk and --cover-art instead of --artwork)http://wiki.hydrogenaud.io/index.php?title=EAC_placeholderssays to use %source% for the Source filename and %dest% for the Output [Destination] filename.so the Additional command-line options for the first test.Code: [Select]%source% -o %dest%You can add other options (including tags) one at a time and check for errors.
