Topic: Location of playlist (Read 700 times) previous topic - next topic
Hello
I once saved playlists with music that was on the partition E. Now this partition has changed its name and has the letter D. Because of that all playlists are empty. Is there any way to improve it massively and bring playlists back to life. Do I need to specify the folder location from every playlist?
Re: Location of playlist
Hi there,
What type of playlists?
- External playlists you have saved? (M3U format?) - You can edit M3U files in Notepad and do a Edit > Find/Replace to change the drive letter.
- Internal / Static (non-auto) playlists within foobar? - Perhaps Playlist Revive component can restore them if the files are monitored in the media library.
- Auto-playlists? - You'd have to recreate them, no other way. Or perhaps you could change the drive letter in Windows back to E:\
Cheers
