Need ID3 Tag editor recommendation for removing a few strings from ALL tag field 2019-11-01 02:23:21 Hello Eveyone!I have been struggling with this for a past couple of days. I have tried the below options so far and I still haven't found any editor that meets my requirement which are:1) Free editor program if it is possible, else something as cheap as possible.2) I have multiple random words in my tag say, "ABC", "MNO", "XYZ" (either as sole words or a part of field value which should be retained) etc spread across multiple fields within most of my mp3 and flac collection.3) The editor should be able to take multiple inputs in one go and remove all those strings in all the tags possible.Below are the programs I tried so far:1) Bulk Rename utility - This doesn't let me edit tags2) MP3 Tag - No option to input a bunch of strings in one go, if all else fails, I will probably resort to remove all 70+ strings manually using this program3) Renamer - I found that this is good for names but not ID3 tags4) Tag Scanner - I haven't been able to get the preview to work, preview-log page is blank and layout is honestly so different than most windows programs5) MP3 Tag and Replace Software - Looks like only one option that meets my requirements but free version is not useful for me6) MediaMonkey - Installed Regex scripts and SQLViewer extensions but they don't quite meet my needs.7) Foobar - Masstagger - Doesn't allow replacing strings with "Null" or plain remove. Foobar - Tagbox - Similar to what BRU offers in terms of being able to rename file name to Title and no other tags.I looked into NPM packages and regex and honestly, it was what beyond my level of comfort with scripting if it is even possible.Again, I'm looking for a program that is:1) Free2) For WindowsAs I said above, if all else fails, I will have to do it one string at a time, which I don't mind but I'm trying to find a smarter way of there is one. I know there is a paid version but the way I see it, if paid versions exists, most likely there is an open-source version too.Thank You!!Edit: I will continue to try various other freeware editors and post an update if I end up finding the solution. But, I also hope, someone has found the solution already and that they would share it. Last Edit: 2019-11-01 02:25:14 by jauid4me
Re: Need ID3 Tag editor recommendation for removing a few strings from ALL tag field Reply #1 – 2019-11-01 16:21:48 Quote from: jauid4me on 2019-11-01 02:23:21Foobar - Masstagger - Doesn't allow replacing strings with "Null" or plain remove.Actually it can do this. You need to use "Format value from other fields" together with function $replace For example $replace(%title%,blah,) will completely remove any occurrence of "blah" from title. You can format new value of field from old value of this field. If field becomes empty, it will be removed completely. Last Edit: 2019-11-01 16:45:03 by Rollin
Re: Need ID3 Tag editor recommendation for removing a few strings from ALL tag field Reply #2 – 2019-11-01 17:04:31 Quote from: Rollin on 2019-11-01 16:21:48Quote from: jauid4me on 2019-11-01 02:23:21Foobar - Masstagger - Doesn't allow replacing strings with "Null" or plain remove.Actually it can do this. You need to use "Format value from other fields" together with function $replace For example $replace(%title%,blah,) will completely remove any occurrence of "blah" from title. You can format new value of field from old value of this field. If field becomes empty, it will be removed completely.Ok, I shall give this a shot. Thank you!
