Topic: Foobar 1.5 beta 20: 6ch DTS WAV details issue (Read 275 times) previous topic - next topic
In Foobar 1.5 beta 20, a 6 channel DTS WAV shows as 2 ch/16 bit under Properties->Details.  However, it shows as 6ch on the frame of the main screen.  Not sure if this is foobar bug or the DTS  component bug.  Thanks.
Re: Foobar 1.5 beta 20: 6ch DTS WAV details issue
This is a limitation of how decode post processors work. They can only report decoded track information as dynamic metadata.
I was going to suggest to Peter to perhaps support caching the last reported dynamic metadata values (just the ones altered by dynamic updates) for a given file or web stream, perhaps either in the media library, if it's a media library indexed file, and/or in playlists which contain the given track. And this would require a way for properties to display this cached information.
A workaround is to remux the file into Matroska or MP4 container, using FFmpeg, so it knows it's a DTS-WAV to begin with:
ffmpeg -i dts.wav -c:a copy dts.mp4
or
ffmpeg -i dts.wav -c:a copy dts.mka
I was going to suggest to Peter to perhaps support caching the last reported dynamic metadata values (just the ones altered by dynamic updates) for a given file or web stream ...
In my experience this is already done for some time for web streams. Encoder details like Bitrate, Channels and tags like Title, Genre, URL and SERVER are kept (I guess in the playlist as streams are not in the library).
note that these are streams that don't need post decoding.
