Topic: mixxx - high speed autodj recording? (Read 513 times) previous topic - next topic
i wonder if it is possible to record a playlist in high speed with mixxx?
Re: mixxx - high speed autodj recording?
i take up the topic again, because it is obviously not possible with mixxx.
have you got a recommendation for another linux program with this feature (highspeed recording of a "replaygained" autodj mix)?
Record from where (or what)?
mixing individual songs (hdd) to one wav file. this is possible with mixxx, but in realtime only.
Hello.
Correct, Mixxx can only run in realtime because it is expected that you want to listen to it.
The Auto DJ will be improved in 2.3 but there is no interest in adding any offline-mode to it.
As for your use case, I believe that you should look for DAWs  ( Digital audio workstations ) like Ardour or the likes.
Or if you don't wan't to got that far, some kinds of mixes could be done on Audacity using envelopes.
You would simply need to load all the tracks you want into Audacity, align them the way you want and add the envelopes. Then export to wav and there you have, mix done.
thank you for clarification.i  will have a look at the programs you mentioned.
