Topic: Some questions about playback (Read 1373 times) previous topic - next topic
I have some questions about playback nad playlist manager API.
1. Has any method to set play track by metadb? I only find a method that set it to focus item and then call play.
2. How playlist_manager::playlist_execute_default_action work? I mean what will be called when playlist_manager::playlist_execute_default_action are executed?
foobar2000's document is really difficult to find, and the foo_sample is also not include this.
Thanks for help.
Re: Some questions about playback
1. You can use playback queue for this. E.g. media library viewer seems to work such way (its context menu item "Play"). Example:
metadb_handle_ptr myhadle = GetItSomeWay();
static_api_ptr_t<playlist_manager> pm;
pm->queue_flush();
pm->queue_add_item(myhandle);
static_api_ptr_t<playback_control>()->start();
2. As the comment in source code states, it starts playing the item unless playlist is "locked", which means playlist_manager::playlist_lock_install was called on it. In this case playlist_lock::execute_default_action of the lock instance is called and it is up to the lock what to do.
