Topic: 1.5b19 REM COMMENT . in CUE Sheet is not removable via Properties or Masstagger (Read 360 times) previous topic - next topic
Hello,
I have a nice cue file with also a line
REM COMMENT .
(EDIT: the mp3 file asociated to the .cue file also has a . in the COMMENT field.)
In f2k,
the COMMENT field in the playlist (CUI) shows the dot ,
Case1:
the Properties Window does not show the dot. Comment Field is shown empty.
Case2:
the Properties Window does show the dot too. But when I  remove the dot, its not removed after applying the changes.
I can not simply remove the dot from the COMMENT field? (not altering the *.cue file, of course)
Masstagger Script "Remove Field: Comment" does not work.
