Topic: How to identify playlist? (Read 461 times) previous topic - next topic
Is there a variable or other method of representing the playlist the currently playing track is playing from? I'd like to have that information visible in the title bar, along with the song title, etc. I often look at other playlists while a track is playing and then can't remember which playlist is playing at the moment.
Re: How to identify playlist?
There isn't a titleformat string for the playlist. But you can locate the playlist and the track you are playing by double clicking the status bar. It takes you to the currently playing track.
Aha! I didn't know that. That's an acceptable workaround, maybe even better than what I was looking for because it both switches to the playist and highlights the current track. Thanks! I've been looking for a solution on my own for months or years.
If you use ColumnsUI, you can add a little script to show you visually which playlist is playing:
$if(%is_playing%,♪,)
%title%
$ifequal(%size%,0,,[' ('%size%')'])
This code shows the playlist name and the count of files in it. As well, as if it is playing or not.
See the screenshots how to do it.
Ooh aah... I like the look of that. I've been using the Default User Interface, but I'll try this one out soon. Thanks for the tip!
...and just in case, you can copy that useful feature too:
Small jscript code showing currently active playlist (if that is what you are looking for). Works with foo_jscript_panel from marc.
// ==PREPROCESSOR==
// @name "Get some playlist info (15.June.2012)"
// @author "ExtremeHunter"
// ==/PREPROCESSOR==
function RGB(r, g, b) {
    return (0xff000000 | (r << 16) | (g << 8) | (b));
function getPlaylistInfo() {
    activePlaylist = plman.ActivePlaylist;
    getPlaylistItems = plman.GetPlaylistItems(activePlaylist);
    playlistItemCount = plman.PlaylistItemCount(activePlaylist);
    seconds = 0;
    sizeInBytes = 0;
    timeFormat = function (s) {
        var weeks = Math.floor(s / 604800),
            days = Math.floor(s % 604800 / 86400),
            hours = Math.floor((s % 86400) / 3600),
            minutes = Math.floor(((s % 86400) % 3600) / 60),
            seconds = (((s % 86400) % 3600) % 60).toFixed(0),
            weeks = weeks > 0 ? weeks + "wk " : "",
            days = days > 0 ? days + "d " : "",
            hours = hours > 0 ? hours + ":" : "",
            minutes = (minutes < 10 ? "0" + minutes : minutes) + ":",
            seconds = seconds < 10 ? "0" + seconds : seconds;
        return weeks + days + hours + minutes + seconds;
    var tempFileName;
    for (var i = 0, l = playlistItemCount; i != l; i++) {
        seconds += parseFloat(fb.TitleFormat("%length_seconds_fp%").EvalWithMetadb(getPlaylistItems.Item(i)));
        fileName = fb.TitleFormat("$filename(%_path%).$ext(%_path%)").EvalWithMetadb(getPlaylistItems.Item(i));
        if (fileName != tempFileName) {
            sizeInBytes += Math.floor(fb.TitleFormat("%filesize%").EvalWithMetadb(getPlaylistItems.Item(i)));
        tempFileName = fileName;
    var sizeInMB = sizeInBytes / 1048576;
    var sizeInGB = sizeInBytes / 1073741824;
    if (sizeInMB < 1024) size = Math.floor(sizeInMB) + " MB";
    else size = Math.floor(100 * sizeInGB) / 100 + " GB";
    window.Repaint();
getPlaylistInfo();
function on_paint(gr) {
    gr.GdiDrawText("Playlist: " + plman.GetPlaylistName(activePlaylist) + "\n" + playlistItemCount + " Items" + (sizeInBytes ? "\nTotal time: " + timeFormat(seconds) + "\nSize: " + size : ""), gdi.font("Segoe Ui", 24, 0), RGB(0, 0, 0), 20, 20, 1000, 500, 0x00000004);
function on_playlist_switch() {
    getPlaylistInfo();
function on_playlist_items_added(playlist) {
    getPlaylistInfo();
function on_playlist_items_removed(playlist, new_count) {
    getPlaylistInfo();
