Topic: Field w/ Multiple Entries Delimited by Semi-Colon Shows Up Separately in Facets (Read 292 times) previous topic - next topic
I have a %MOOD% field which I use to categorize tracks. Each song can have multiple moods which I separate with the semi-colon
However, in Facets newly tagged songs with multiple moods delimited are showing up as a separate entry
I have tagged tons of songs previously using this same format with no issues - also using latest foobar 1.4.8
Any ideas?
Re: Field w/ Multiple Entries Delimited by Semi-Colon Shows Up Separately in Facets
select all your tracks>get properties.
Ctrl/right click on %mood%>Split Values...
And add MOOD to preferences so future tagging gets split automatically...
(Preferences > Advanced > Display > Properties dialog > Multivalue fields)
@anamorphic double checked and it was already there
@mjm716 That did the trick!
Thanks for your help!!
