Topic: Not Following CUE Sheet File Path (Read 228 times) previous topic - next topic
CUETools not following file path in CUE file.
It's using the wav file in the current folder instead of the file specified in cue sheet.
FILE "folder\cd.wav" WAVE
FILE ".\folder\cd.wav" WAVE
FILE "C:\folder\cd.wav" WAVE
Regardless if an absolute or relative path is specified, cd.wav in the current folder is used if it exists.
Re: Not Following CUE Sheet File Path
So the file names are not unique?
If there is a wav file with the same name (as in the CUE file) in the current folder then CUETools will attempt to use that file.
If the path in the CUE file is not valid and an audio file exists in the current folder then CUETools will attempt to use that file (when Locate audio files if missing is checked).
korth
Would think the order should be...
1) the file path specified in the cue file.
2) wav file with same name (as CUE file) in the current folder.
3) attempt to find audio feature.
