Topic: Is there actually a way to remove or edit "details" information from MP3 files? (Read 685 times) previous topic - next topic
In case you don't know what I mean.
Here is a screenshot:
I know, first world problems. I personally just dont need the info at all and it looks ugly anyway. So far I have found no program that can remove or edit these information. Not all MP3s come with them. Probably up to the encoder used.
Maybe somebody knows a way? I tried tools like MP3Tag but they dont even show this kind of information, doesnt seem to be saved in tags anyway.
Re: Is there actually a way to remove or edit "details" information from MP3 files?
This information is necessary for gapless playback, BTW.
What about right-clicking in that pane and unselecting "Other"? Out of sight, out of mind?
The only other "Other" information I've seen, is for foo_youtube - and then two Matroska fields: <STREAM_LANGUAGE> in Matroska (dunno how to change that, but I don't care enough) and <CHANNEL_MODE>.
A minor inconsistency though:
Normally if I select several files which share a tag value, fb2k shows it. But if I select for example several Matroska chapters from the same file, and which all share the same <STREAM_LANGUAGE>, the info field disappears.
