Topic: YEAR [$year(%date%)] column displays correctly in Playlist View but not Facets (Read 492 times) previous topic - next topic
Thanks to help from anamorphic, I have been merrily entering album release data using YYYY-MM-DD format from some LP's and checking the results, when I decided to take a look in Facets. I added the [$year(%date%)] string under Facet Preferences, but Year doesn't display any data yet Month-Day is fine. Please see attached screenshots, one showing Playlist View with Year displaying correctly and the other showing Facets with Year empty, both using the same string in their respective Preferences. Any idea what I am missing?
Re: YEAR [$year(%date%)] column displays correctly in Playlist View but not Facets
Hi again,
Seeing you have two Year columns in Facets Preferences, the old one might still be shown. Try re-selecting the Year column (right-click 'Year' column header > Columns > select first 'Year' in the list).
You can probably delete the old [%year%] in Preferences, too, if no longer using that tag.
Cheers
Once again, you are right. Thanks! :) :)
