Topic: Add moved items in to library instantly (Read 2505 times) previous topic - next topic
Not a problem as I know the library will eventually be updated but if I moved a file into a directory that's in my library perhaps Foobar could check against the library locations and if the file is moved to one of those perhaps automatically add it to the library? Thanks.
Re: Add moved items in to library instantly
By default the library paths are monitored and new files added in them are instantly in the media library. The feature can be disabled from the path's right click context menu. Monitoring doesn't work on very old Samba used in some NAS devices.
Thanks Case, I can see it working fine now using Beta 14, unsure why it wasn't updating instantly before.
