Topic: Specific radio stream's authentication failure (Read 317 times) previous topic - next topic
When attempting to play the stream URL https://neon.sochilounge.ru/5790 (Sochi Lounge Neon), the following message is received:
The following error(s) occurred during loading of the location(s):
Network authentication error (800b010f)
Same stream plays fine in AIMP, MusicBee, and XMPlay.
Re: Specific radio stream's authentication failure
They shouldn't play it because the certificate is not valid:
neon.sochilounge.ru uses an invalid security certificate.
The certificate is only valid for the following names: listen1.myradio24.com, www.listen1.myradio24.com
Error code: SSL_ERROR_BAD_CERT_DOMAIN
There is option in Advanced preferences to suppress certificates check for selected domains. It works with this stream.
Thanks Rollin!
