ABX Media Players 2019-09-06 03:30:44 Do you hear any difference in output when you switch between player app A and B?Here's a comparison test with a different twist (I hope!)....Take a bunch of CD Rips (in WAV format if possible - so there is no conflict whether the format is the issue) and play them on two different PC based media players - eg. FB2K, MonkeyMedia, VLC and others - at the same time.Listen carefully using your best DAC and best pair of headphones. I do this on Windows OS by playing both in sync, then opening Volume Mixer and muting one app or the other. Make sure they are output level-matched. Of course turn Off all additional processing like equalization etc!So what's your result, 1, 2 or 3?1. I don't hear any difference.2. Slight difference, hard to pin down exactly what it is.3. Huge difference (eg. "one is shrill, the other smooth sounding", etc)Please enter your vote here...https://forms.gle/tnpcy2SU5HGZSfaE6 Last Edit: 2019-09-06 03:45:47 by skris88
Re: ABX Media Players Reply #1 – 2019-09-06 03:55:17 If you want to test if there is a difference, just record the output and check.
Re: ABX Media Players Reply #2 – 2019-09-06 22:44:38 Quote from: skris88 on 2019-09-06 03:30:44I do this on Windows OS by playing both in sync, then opening Volume Mixer and muting one app or the other.This is not an ABX test.
