Topic: libavcodec/libfdk-aacenc.c error while compiling ffmpeg (Read 8121 times) previous topic - next topic
Hello!
I've been suggested to write in this forum because of my problem with libfdk-aacenc.c error while compiling ffmpeg.
Summarizing:
I'm trying to install FFMPEG on my Raspeberry following this procedure: https://gist.github.com/adddog/d82581faf10d666d35b9771eaa65d5ac.
While doing this step of the procedure:
sudo apt-get install -y xserver-xorg-dev libxext-dev build-essential libxi-dev libglu1-mesa-dev libglew-dev
wget http://www.ijg.org/files/jpegsrc.v9c.tar.gz
tar xvfz jpegsrc*
cd jpeg-9c
./configure --enable-shared --prefix=$CONFIGURE_PREFIX
make -j4
sudo make install
I'm getting this error while compiling:
libavcodec/libfdk-aacenc.c:289:34: error: ‘AACENC_InfoStruct {aka struct <anonymous>}’ has no member named ‘encoderDelay’; did you mean ‘nDelay’?
Can you please help me?  :(
Re: libavcodec/libfdk-aacenc.c error while compiling ffmpeg
There was a major API change on libfdk-aac side (FDKv2) on 2018-8-31, and the error is because you are using recent libfdk-aac and old ffmpeg that does not yet support newer API.
You need ffmpeg at least newer than this commit:
commit ffb9b7a6bab6c6bfd3dd9a7c32e3724209824999
Author: Martin Storsjö <martin@martin.st>
Date:   Tue Sep 4 11:29:37 2018 +0300
Hi nu774 . Can you help me to understand which step shall I update of this procedure? (
 https://gist.github.com/adddog/d82581faf10d666d35b9771eaa65d5ac)
While failing, I was doing steps from 54 to 58. Shall I change the release in line 54? Or remove/add anything in line 56 (.configure)
Thanks a lot!
Regards!
I can't answer your question because I don't know why the script specifically fetches 3.4 branch of ffmpeg.
Alternatively, you can fetch older release of fdk-aac from here: https://github.com/mstorsjo/fdk-aac/archive/v0.1.6.tar.gz
How to fetch old release? Can you explain me the procedure?
I'm under no obligation to feed you from a spoon, don't PM me about this.
Why don't you ask the guy who wrote it?
I asked him but it seems to be worst than you to give advice. If you don't want to give me support it doesn't matter. I don't like people behaving like you. I prefer to don't solve the issue rather than crying to get your help.
The reason why I'm pushing you via PM is because it's more than a week trying to install this package but unfortunately the code is bugged. If the code would have been bug-free I would not have any reason to open this post.
At some point if I'll not solve the issue alone I'll escalate to someone having a higher rule in order to educate who write open source code on how to correctly answer users like me.
Thanks a lot! Really!
