Topic: Help! CueTools error: Access to path denied (Read 3718 times) previous topic - next topic
Hello
I have been using EAC to rip my discs for the past few years, and much more recently I discovered that I could fix not-quite-right rips using CueTools. I do remember that it was not very intuitive to learn the process, but have been successful a few times.
However, I recently had my HD crash and had to install Windows (7) from scratch. I have now downloaded CueTools 2.1.6 (which is the same version I last used), but am experiencing the following error:
Exception: Access to the path 'C:\some\path\that\doesnt\exist\and\is\not\referenced\anywhere\in\the\software' is denied.
Could one of you folks with more experience than I please help me to figure it out?
Brian
Re: Help! CueTools error: Access to path denied
Thank you for your swift reply.
Unfortunately, nothing in that thread seems to be relevant to my issue.
I have checked the .cue file and there are no characters that could not be used in a path name or file name.
Incidentally, the path that it is telling me is denied is 'C:\users\Brian\Documents\My videos', which I find very odd as I cannot for the life of me imagine a reason that CueTools would want anything in that location. Both the input (.cue file and .wav file) and output (%filename%-new) are pointed to 'C:\users\Brian\Documents'.
Thanks again
Brian
Could you post the contents of the CUE anyway (and the filename)?
korth
Here is the .cue file and the .log file just for good luck.
Incidentally, I moved the three files (.cue, .wav and .log) to a network drive and the CueTools repair went without a hitch.
REM GENRE Rock
REM DATE 1981
REM DISCID AE114210
REM COMMENT "ExactAudioCopy v1.3"
PERFORMER "Bob Seger"
TITLE "Nine Tonight"
REM COMPOSER ""
FILE "Bob_Seger~Nine_Tonight-x.wav" WAVE
  TRACK 01 AUDIO
    REM COMPOSER ""
    INDEX 00 00:00:00
    INDEX 01 00:00:33
  TRACK 02 AUDIO
    TITLE "Tryin' To Live My Life Without You"
    REM COMPOSER ""
    INDEX 00 05:15:00
    INDEX 01 05:15:08
  TRACK 03 AUDIO
    TITLE "You'll Accomp'ny Me"
    REM COMPOSER ""
    INDEX 00 09:18:50
    INDEX 01 09:18:58
  TRACK 04 AUDIO
    TITLE "Hollywood Nights"
    REM COMPOSER ""
    INDEX 00 13:31:12
    INDEX 01 13:31:18
  TRACK 05 AUDIO
    TITLE "Old Time Rock And Roll"
    REM COMPOSER ""
    INDEX 00 18:20:64
    INDEX 01 18:20:70
  TRACK 06 AUDIO
    TITLE "Mainstreet"
    REM COMPOSER ""
    INDEX 00 23:38:18
    INDEX 01 23:38:25
  TRACK 07 AUDIO
    TITLE "Against The Wind"
    REM COMPOSER ""
    INDEX 00 27:50:55
    INDEX 01 27:50:63
  TRACK 08 AUDIO
    TITLE "The Fire Down Below"
    REM COMPOSER ""
    INDEX 00 33:18:28
    INDEX 01 33:18:35
  TRACK 09 AUDIO
    TITLE "Her Strut"
    REM COMPOSER ""
    INDEX 00 38:05:35
    INDEX 01 38:05:43
  TRACK 10 AUDIO
    TITLE "Feel Like A Number"
    REM COMPOSER ""
    INDEX 00 42:03:00
    INDEX 01 42:03:08
  TRACK 11 AUDIO
    TITLE "Fire Lake"
    REM COMPOSER ""
    INDEX 00 49:57:64
    INDEX 01 49:58:48
  TRACK 12 AUDIO
    TITLE "Betty Lou's Gettin' Out Tonight"
    REM COMPOSER ""
    INDEX 00 50:04:73
    INDEX 01 50:05:05
  TRACK 13 AUDIO
    TITLE "We've Got Tonight"
    REM COMPOSER ""
    INDEX 00 53:04:36
    INDEX 01 53:04:43
  TRACK 14 AUDIO
    TITLE "Night Moves"
    REM COMPOSER ""
    INDEX 00 57:59:74
    INDEX 01 58:00:05
  TRACK 15 AUDIO
    TITLE "Rock And Roll Never Forgets"
    REM COMPOSER ""
    INDEX 00 63:44:03
    INDEX 01 63:44:10
  TRACK 16 AUDIO
    TITLE "Let It Rock"
    REM COMPOSER ""
    INDEX 00 67:19:63
    INDEX 01 67:19:68
Exact Audio Copy V1.3 from 2. September 2016
EAC extraction logfile from 23. August 2019, 16:55
Bob Seger / Nine Tonight
Used drive  : PIONEER BD-RW   BDR-209D   Adapter: 1  ID: 1
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 667
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.33 |  5:14.50 |        33    |    23632
        2  |  5:15.08 |  4:03.50 |     23633    |    41907
        3  |  9:18.58 |  4:12.35 |     41908    |    60842
        4  | 13:31.18 |  4:49.52 |     60843    |    82569
        5  | 18:20.70 |  5:17.30 |     82570    |   106374
        6  | 23:38.25 |  4:12.38 |    106375    |   125312
        7  | 27:50.63 |  5:27.47 |    125313    |   149884
        8  | 33:18.35 |  4:47.08 |    149885    |   171417
        9  | 38:05.43 |  3:57.40 |    171418    |   189232
       10  | 42:03.08 |  7:55.40 |    189233    |   224897
       11  | 49:58.48 |  0:06.32 |    224898    |   225379
       12  | 50:05.05 |  2:59.38 |    225380    |   238842
       13  | 53:04.43 |  4:55.37 |    238843    |   261004
       14  | 58:00.05 |  5:44.05 |    261005    |   286809
       15  | 63:44.10 |  3:35.58 |    286810    |   302992
       16  | 67:19.68 |  6:18.32 |    302993    |   331374
Range status and errors
Selected range
     Filename C:\Users\Brian\Documents\Bob_Seger~Nine_Tonight-x.wav
     Suspicious position 1:12:25
     Peak level 100.0 %
     Extraction speed 7.2 X
     Range quality 99.9 %
     Copy CRC F1114291
     Copy finished
There were errors
AccurateRip summary
Track  1  accurately ripped (confidence 1)  [1EA25F3A]  (AR v1)
Track  2  accurately ripped (confidence 2)  [37AC16B2]  (AR v1)
Track  3  cannot be verified as accurate (confidence 1)  [52DC7FD4], AccurateRip returned [FD5A51A2]  (AR v2)
Track  4  accurately ripped (confidence 1)  [63743EC3]  (AR v1)
Track  5  cannot be verified as accurate (confidence 1)  [7F730432], AccurateRip returned [CFCCF5B8]  (AR v2)
Track  6  cannot be verified as accurate (confidence 1)  [6D7AE8FA], AccurateRip returned [18B38A16]  (AR v2)
Track  7  cannot be verified as accurate (confidence 1)  [45B714F2], AccurateRip returned [0FB47147]  (AR v2)
Track  8  cannot be verified as accurate (confidence 1)  [0783B6AB], AccurateRip returned [6EA7E2A8]  (AR v2)
Track  9  cannot be verified as accurate (confidence 1)  [EF8B04E3], AccurateRip returned [D9FBC501]  (AR v2)
Track 10  cannot be verified as accurate (confidence 1)  [CA607214], AccurateRip returned [1570A137]  (AR v2)
Track 11  accurately ripped (confidence 2)  [2DC28C40]  (AR v1)
Track 12  cannot be verified as accurate (confidence 1)  [1398DFDA], AccurateRip returned [724EF291]  (AR v2)
Track 13  cannot be verified as accurate (confidence 1)  [19174053], AccurateRip returned [51A404A7]  (AR v2)
Track 14  cannot be verified as accurate (confidence 1)  [B0F09DD5], AccurateRip returned [0F2464C1]  (AR v2)
Track 15  cannot be verified as accurate (confidence 1)  [A69A149D], AccurateRip returned [CAB38D4B]  (AR v2)
Track 16  cannot be verified as accurate (confidence 1)  [7D634E54], AccurateRip returned [950281E2]  (AR v2)
 4 track(s) accurately ripped
12 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: 6LzAM8rgqy5fSWkES1Ms1F5BXr0-] found
Submit result: 6LzAM8rgqy5fSWkES1Ms1F5BXr0- has been submitted
Track | CTDB Status
  1   | (2/2) Accurately ripped
  2   | (2/2) Accurately ripped
  3   | (2/2) Differs in 5 samples @03:46:35
  4   | (2/2) Accurately ripped
  5   | (2/2) Accurately ripped
  6   | (2/2) Differs in 9 samples @02:11:66,03:09:69,03:12:04
  7   | (2/2) Differs in 4 samples @00:05:10
  8   | (2/2) Differs in 6 samples @03:30:63,03:55:57
  9   | (2/2) Accurately ripped
 10   | (2/2) Differs in 2 samples @07:44:60
 11   | (2/2) Accurately ripped
 12   | (2/2) Accurately ripped
 13   | (2/2) Differs in 5 samples @04:40:34
 14   | (2/2) Accurately ripped
 15   | (2/2) Differs in 10 samples @00:21:14,03:02:44
 16   | (2/2) Accurately ripped
If you are sure that your rip contains errors, you can use CUETools to repair it.
Although there is now no longer any urgency, I would like to know why the error was thrown on the local drive, but not on the network drive.
Just for giggles, I tried every .cue/.wav pair in my Documents directory before moving that set and every one of them failed with the same error.
It might be beneficial to add that the file system is NTFS on my Windows machine and ZFS on the network drive.
Brian
Do all the rips that failed have the tilde '~' in the filename?
korth
All of my files have the tilde in the filename. Good rips, bad rips, album cover art, concert dvd rips, etc etc. It's my favourite separator character because it's seldom found anywhere else.
I have never before had any issue. (However, I am not completely sure (only half sure) that I have ever run CueTools on a file that was on the local Windows drive; I save everything to the NAS.)
Brian
I haven't been able to duplicate the Exception so far. I'm not having an issue with the tilde on Win10 either so just pulling straws perhaps.
korth
