Topic: 1.5b9 plugin Waveform Seekbar don't scan new files (Read 2582 times) previous topic - next topic
File scanning is not working in the latest beta 1.5_beta_9 version. The previous beta version 1.5_beta_7 works fine. Please check this.
Re: 1.5b9 plugin Waveform Seekbar don't scan new files
Hi there,
foo_wave_seekbar 0.2.45 works fine for me on a fresh install of fb 1.5b9. (Aside from the existing issue of foreground colors having a strange bloom effect for some time now...)
Are you perhaps using the new decoder based foo_skip 1.10.x? I noticed when it is disabled under Playback menu > Skip Tracks, new waveforms for foo_wave_seekbar were not generated. With foo_skip enabled it works again. I meant to tell @Case a few days ago but actually forgot all about it. :-[
Cheers
Hi there,
Cheers
Yes exactly, I have installed the latest beta version (Skip Track 1.15beta1). In this case, ticked or unticked under Playback menu > Skip Tracks do not solve the problem. I installed the last stable version 1.10.3 and in this case it is exactly as you write. Thank you for guiding me on the right track, because I didn't know what caused this problem :)
I'm innocent. Seekbar 0.2.45.6 here doesn't scan a test mp3 file even in a clean profile without any other third party components. 0.2.45 did but it could be a coincidence. Peter has been notified.
In the new beta version 1.5_beta_10 all works as it should, thanks  :D
