Topic: Clear data from 'Album List' pane  (Read 911 times) previous topic - next topic
New with foobar2000.  I just can't figure out how to clear the data from the Album List pane.
The Artist/Album pane has the ability to "Remove" all items, but I cannot clear or delete the data from the Album List pane so that I am "starting from scratch."
Thank you for any hints.
Re: Clear data from 'Album List' pane
Hi there,
Album List shows the contents of folders that foobar is monitoring. It is an automatic index of your music. There is typically no need to "clear it" as foobar keeps any changes to files and folders up-to-date. However you can add or remove folders by Library menu > Configure > under Music Folders. You can also right-click the folder paths listed there to change scan options.
Cheers
Great, thank you very much.  Very helpful!  :)
