Topic: (v1.5b7) Masstagger does not remove COMMENT field via script. (Read 1512 times) previous topic - next topic
About the very useful and everyday used component: https://www.foobar2000.org/components/view/foo_masstag (1.8.4, released on 2009-09-18)
Hello Peter,
very long COMMENT tags are not removable via Masstagger script: Remove Comment.
Preview says, comment is removed, but its not. (screenshot: masstagger window)
Reprocucable in v1.5.b7 ...and every other f2k since 2009 :-)
Example of very long comment:
Comment : FSB-7; 0;  000004C7 000002C6 00004F84 00002624 00020B29 00020678 00007E87 00007E87 0000296D 00002E1F;  00000000 00000210 00000A1C 0000000000BA4354 00000000 00A8DC93 00000000 00000000 00000000 00000000 00000000 00000000FSB-7; 0;  000004C7 000002C6 00004F84 00002624 00020B29 00020678 00007E87 00007E87 0000296D 00002E1F;  00000000 00000210 00000A1C 0000000000BA4354 00000000 00A8DC93 00000000 00000000 00000000 00000000 00000000 00000000FSB-7; 0;  000004C7 000002C6 00004F84 00002624 00020B29 00020678 00007E87 00007E87 0000296D 00002E1F;  00000000 00000210 00000A1C 0000000000BA4354 00000000 00A8DC93 00000000 00000000 00000000 00000000 00000000 00000000FSB-7; 0;  000004C7 000002C6 00004F84 00002624 00020B29 00020678 00007E87 00007E87 0000296D 00002E1F;  00000000 00000210 00000A1C 0000000000BA4354 00000000 00A8DC93 00000000 00000000 00000000 00000000 00000000 00000000FSB-7; 0;  000004C7 000002C6 00004F84 00002624 00020B29 00020678 00007E87 00007E87 0000296D 00002E1F;  00000000 00000210 00000A1C 0000000000BA4354 00000000 00A8DC93 00000000 00000000 00000000 00000000 00000000 00000000FSB-7; 0;
I can attach a sample mp3 file if nobody can reproduce.
EDIT: Darn, wrong forum, sorry! Should be in 3rd Party Plugins
Re: (v1.5b7) Masstagger does not remove COMMENT field via script.
Today I've read about LargeFieldsConfig.txt, but
I'm not sure, if this file (and its contents) is also responsible for the masstagger component not working as expected (remove comment fields).
Ok,
via google I found this useful Post by marc2003, and after increasing the defaultMetaMax parameter in LargeFieldsConfig.txt (and restarting f2k), masstager was able to du remove the COMMENT tag.
Anyways, problem solved, but I would call this a still bug, because
a)
why in the world has removing a tag from a file something to do with caching?
b)
nobody in the world could guess right, why the tag is not removed.
c)
f2k/masstagger does show the user in the preview window, that the tag will be removed, which is not the case when executing the script.
d)
it is a buggish behave :-)
Masstagger was released in September 2009, LargeFieldsConfig.txt was introduced in foobar2000 1.3 (December 2013).
So probably masstagger just doesn't know how to work with such fields. Also, apparently it was abandoned, so I doubt that it will be fixed.
Well?
Any feedback, even "installed, seems to work OK" is welcome, from someone who actually uses the component extensively.
I'm trying not to push untested versions to everyone via auto update.
I installed it in 1.5 beta, imported my huge title case script from the old version, and it processed some files fine, even if the title was longer than caching limit and showed as a period. Seems to work.
Thank you very much.
