Topic: Runtime Error R6025 (Read 2715 times) previous topic - next topic
Runtime Error R6025
Greetings!
I've been getting this message for quite some time now, even on freshly formatted Windows installations etc.
Curious thing is that it show only when I close Foobar and some (few) times, the error doesn't appear.
I doesn't seem to be affecting the functionality or play history whatsoever.
I also think that this started happening since some versions into the 1.4 build.
Any thoughts or solution?
Re: Runtime Error R6025
You could check Application section of Windows Logs in Event Viewer. Crash report there might name a component causing the problem.
If you are not that lucky update everything. If that doesn't solve the issue run Online troubleshooter found under the Help main menu. If it can't point a broken component you could post a list of your components in case someone here knows something foobar's crash tracker can't see.
Or manually find out the bad component by removing components one at a time or do a portable test install where you add your components one at a time.
Thank you for replying.
Well through the Event Viewer it seems that the problem is the foo_ui_columns.dll, so I visited the author's site and installed an update, but the problem insists.
To be truthful, I do not understand what the log's info point out to, so I'm posting a screenshot here for reference if someone can provide some insight.
Could you post a list of your installed components? (There should be a button to copy them to the clipboard on the Components page in preferences.)
Certainly.
Core (2019-07-07 08:11:44 UTC)
    foobar2000 core 1.4.6
foo_albumlist.dll (2019-07-07 08:11:06 UTC)
    Album List 4.6
foo_bookmarks.dll (2010-12-08 14:17:59 UTC)
    Bookmarks 0.3.3.4
foo_cdda.dll (2019-07-07 08:11:04 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2019-07-07 08:11:06 UTC)
    Converter 1.5.3
foo_dsp_eq.dll (2019-07-07 08:10:56 UTC)
    Equalizer 1.2.1
foo_dsp_soundtouch.dll (2010-12-08 14:18:33 UTC)
    SoundTouch DSP 0.1 (SSE)
foo_dsp_std.dll (2019-07-07 08:10:56 UTC)
    Standard DSP Array 1.3.2
foo_fileops.dll (2019-07-07 08:11:04 UTC)
    File Operations 2.3
foo_freedb2.dll (2019-06-28 18:42:26 UTC)
    Online Tagger 0.7
foo_input_monkey.dll (2019-04-26 11:30:48 UTC)
    Monkey's Audio Decoder 2.2.3
foo_input_sacd.dll (2019-07-20 05:56:52 UTC)
    Super Audio CD Decoder 1.1.3
foo_input_std.dll (2019-07-07 08:11:30 UTC)
    FFmpeg Decoders 3.4.5
    Standard Input Array 1.4.6
foo_navigator.dll (2010-12-08 14:19:38 UTC)
    Navigator 0.63
foo_playcount.dll (2019-03-11 16:44:28 UTC)
    Playback Statistics 3.0.3
foo_queuecontents.dll (2019-03-03 08:46:39 UTC)
    Queue Contents Editor 0.5.1
foo_quicktag.dll (2010-12-08 14:21:31 UTC)
    Quick Tagger 1.0.3
foo_rg_trn.dll (2010-12-08 14:21:37 UTC)
    ReplayGain override 0.1.3
foo_rgscan.dll (2019-07-07 08:11:12 UTC)
    ReplayGain Scanner 2.3
foo_run.dll (2019-03-03 08:46:39 UTC)
    Run services 0.3.8
foo_ui_columns.dll (2019-07-28 10:43:56 UTC)
    Columns UI 1.1.0
foo_ui_std.dll (2019-07-07 08:11:12 UTC)
    Default User Interface 1.4.6
foo_uie_albumart.dll (2010-12-08 14:22:07 UTC)
    Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2019-03-03 08:47:46 UTC)
    Album list panel 0.4.0-beta.5
foo_uie_console.dll (2010-12-08 14:22:16 UTC)
    Console panel 0.4
foo_uie_graphical_browser.dll (2010-12-08 14:22:29 UTC)
    Graphical Browser rev015
foo_uie_lyrics3.dll (2019-03-03 08:47:40 UTC)
    Lyric Show Panel 3 0.5
foo_uie_playlists_dropdown.dll (2010-12-08 14:22:38 UTC)
    Playlists Dropdown 0.7.6
foo_uie_quicksearch.dll (2010-12-08 14:22:43 UTC)
    Quick Search Toolbar 2.8l
foo_uie_vis_channel_spectrum.dll (2010-12-08 14:22:47 UTC)
    Channel Spectrum panel 0.17.2
foo_unpack.dll (2019-07-07 08:11:04 UTC)
    ZIP/GZIP/RAR Reader 1.8
foo_utils.dll (2010-12-08 14:22:52 UTC)
    Playlist Tools 0.6.2 beta 6
You have multiple components listed as known problematic components by the online troubleshooter (accessible from the Help menu). I'd try removing those to see if the problem goes away.
You can also send me the .dmp file generated by Windows (mentioned in the event log entry above) and I can see if it pinpoints anything in particular.
Hm, this looks weird. The dmp file and the others are not available.
What is though is a "Report.wer" file in the path:
"C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_foobar2000.exe_1cfe9ee5b52a89167448c396fe5721e97bb14a5_71f86cfa_79bc6e38-9712-4c5d-9e1a-10ec2cfdef57"
I'm attaching it.
Also I tried removing some components like you said except for  Lyric Show Panel 3 0.5 and Navigator 0.63, but I still get the exact same error.
I should point out that I've been using the same components more or less, for the same theme for more than 7 years or so and there never was a problem.
I'm afraid the .wer file does not contain the .dmp file. You could also send me your foobar2000.cfg file and I can check if I can reproduce it.
Also, when you say it's being happening for some time, how long would you say that is?
Thanks, I was able to reproduce it. There is a bug in Columns UI – it will be fixed for the next version.
Thank you for your time and effort. Looking forward to the fix!
