Topic: converting FLAC TO ALAC and everything translate 1411 BIT RATE (Read 49808 times) previous topic - next topic
AM I doing some thing wrong
thanks
Re: converting FLAC TO ALAC and everything translate 1411 BIT RATE
Uncompressed audio from a CD is about 1411 kbps. If I remember correctly there was an issue with ffmpeg alac files displaying as 1411 kbps in itunes.
Edit: after a couple quick searches
https://hydrogenaud.io/index.php/topic,76768.msg672117.html#msg672117
https://www.google.com/search?q=%22ffmpeg%22+%22alac%22+%221411%22
korth
Why would anyone convert FLAC, a free and open format, to ALAC anyway I wonder.
Suppose you are on a OS not supporting FLAC e.g. OSX?
TheWellTemperedComputer.com
Possible, but I can't imagine that being the case unless OSX is worse than I thought.
macOS supports FLAC the weird Music application doesn't. Wasn't there the comment that the bitrate is pointless for lossless audio anyway?
I'm converting FLAC to ALAC using qaac.  Each track has a different bitrate.  I haven't tried loading them in iTunes yet though.
foobar shows the bitrate correctly though.
The reason for doing this is to put the ALAC files on an iPod Classic that I have replaced the original 160 GB HD with a 512 GB SSD.  I plan on connecting that via USB and using the car's controls to access and play the media.  It's one of the only ways to play back SQ (lossless) media in the car with gapless playback support.
JXL
Apple doesn't support FLAC.
It does, at least QuickTime Player and Quick Look on macOS Catalina. Even metadata when the file is played locally, no idea why this fails when the file is played from an SMB share though.
The music app does not. Old iPod devices do not, and never will without mucking about with third party firmware.
True. I remember that you could convert everything to 128K AAC for the iPod, I wonder if this is still possible. I also remember that I had my CD collection as ALAC once (lost it through hard drive failure) but they were weird for some (forgotten) reason, must have been some bug in sbooth's Rip software. But this is beside the point of the thread.
