Topic: Opus severe issues (Read 94996 times) previous topic - next topic
Re: Opus severe issues
Sounds about normal for a CVBR 32Kbps encode. What issues are you experiencing?
64k cvbr is also sub par even without abx.  What do you mean what issues ? Theres no need to even abx IMO
wavpack 4.8 -b256hx6c
TOS #8 violation, no?
What are you even doing here ? I posted these for Opus Developers and experts to check. And NO  - I DID NOT CLAIM CODEC A IS BETTER THAN B OR VICE VERSA. IMO , I DONT NEED TO ABX IT TO HEAR IT.  Others may need to.
hear what? lossy 32/64kbps sounds like not a cd-quality? thats NEWS!!!
for retreat-
someone hacks your account...
for retreat-
1- Yes according to some 'studies' , personal tests and the mighty HA WIKI  it can come close esp @ 64k.  2 - As i said its not about CD quality per say but rather how gracefully degradation occurs. You can have audio not cd quality but not annoying, Yet another @ CD quality but annoying if trouble spot(s) occurs.
3- When encoding this sample with HE-AAC / vorbis the result is clearly more pleasing to my ears.
4 - The notion that one should not post  / mention audio defects  @ less than tranparent bitrates is nothing more than politicaly correct bullshit . esp since the main attraction of such codecs is low bitrate use.
Is a good sample, not problematic
Jm Valin (I don't know who develops opus apart him) is optimizing most for 24 - 48 kbps -96 kbps (I used today build libopus 20-07-2019)  ffmpeg opus I don't blind tested it  but I think for now it's the same.
At other bitrates I hear flanging in the drums and cymbals, even at 128 kbps.
64 kbps is surpassed. Jm Valin said in this site that he is optimizing more at bitrates 24 - 48 kbps.
I'd like to ask for ABX results where you can detect something like that for Opus@128 kbps
Yesterday I ABXed it but he's expanding for other bitrates. If you tried latest libopus build you'd know that there are lower bitrate available with CELT only minimum 15 kbps but it is trasparent at about 34 kbps (about double the bitrate).
I haven't listened to an audiophile track (it's EDM) and I don't know where to find it.
I decided to test 128k  - with PC speakers only. Half way through the 1st trial i decided to focus on the background noise @ 2sec mark and it becomes more obvious as its not clean. It showed through the 2nd trial.
foo_abx 1.3.4 report
foobar2000 v1.4.3
2019/07/21 21:05:14
File A: G:\Hdd-2\music\abx tests\lame\Richmond Rd Revisited.flac-00.00.00.000-00.00.24.057.flac
File B: G:\Hdd-2\music\abx tests\lame\Richmond Rd Revisited.opus
21:05:14 : Test started.
21:05:36 : 00/01  100.0%
21:05:50 : 00/02  100.0%
21:06:06 : 01/03  87.5%
21:06:16 : 02/04  68.8%
21:06:40 : 03/05  50.0%
21:06:46 : Trial reset.
21:06:59 : 01/01  50.0%
21:07:11 : 02/02  25.0%
21:07:19 : 03/03  12.5%
21:07:57 : 04/04  6.3%
21:08:39 : 05/05  3.1%
21:09:27 : Test finished.
Total: 8/10 (5.5%)
I am not audio engineer and I don't know which version of Opus do you refer.
I 've been playing with several other samples; angels falls 1st, mandylion_sm @ 32..48..64 and came to similar disappointments. However, Getting rid --cvbr yielded a big improvement -except- the richmond road sample that become worse with default VBR. The other trouble is the female speech sample I encoded @32k . It produces unpleasant artifacts . However, 16..24k sounded much better but why ?
log without checksums and attached files... not convinced
You don't get it . This is for developers and these are non-cd quality bitrates so anyone should be able to hear it. I don't care much for 128k or even 96k currently. The issue is the type of error produced and its character. I may upload the samples for devs or others interested but not gonna bother at all with checksums etc.
So you're also implying 128k isn't "cd quality bitrate"?
Total: 8/10 (5.5%)
Very interesting results. I thought that Opus at this bitrate should be transparent in most cases...
Can you detect these issues with AAC (Nero) / Vorbis @128k?
foobar2000 v1.4.3
2019/07/21 21:05:14
Total: 8/10 (5.5%)
Hmmm could you tested on 160k ?
Hmm..... still use Flac & Ogg, planning to Opus but on speaker i found some noise
libopus 1.3.1 ~ libopusenc 0.2.1
