Topic: Wake up foobar2000 after sleep and hibernate (Read 5607 times) previous topic - next topic
Re: Wake up foobar2000 after sleep and hibernate
You can launch the old version if you click Cancel in the warning dialog.
Ок
foobar2000_v1.5_beta_6 - This version works well
Additional safeguards against corrupted configuration in case of a system crash while saving
Crash Test)
Disable Hybrid Sleep mode in the power settings (select "Deny")
Go the playing player to the Sleep mode (NOT Hibernation).
Disconnect  PC from the power => launch the player(After booting  OS).
1.Version foobar2000_v1.4.3.
The configuration file flies (message about damage) - I get the DUI or CUI selection window.
2.foobar2000_v1.5_beta_18.exe - only the message that in the screenshot.
After OK - everything works.
Hello!
I noticed foobar2000 1.5.1 often freezes in processes (encountered on different PCs):
There is an attempt to open a new instance, but there is no window.
In versions 1.4.8 and below, this was not the case.
This happens if  start one copy (which has not yet closed completely) on top of another.
Restart is needed, as some components are synchronized with the system time and try to "catch him" when exiting sleep - that's another problem ..
