Topic: Add the ability to enter the volume with numbers on the keyboard (Read 587 times) previous topic - next topic
Add the ability to enter the volume with numbers on the keyboard. Sometimes you need to specify the exact volume (for example, -16.0 dB). Use the slider or the + - keys to do this uncomfortable. All exact programs and mixers have the ability to input volume from the keyboard, for some reason this is not in foobar2000. Or make a scroll wheel binding to a whole number of dB, in the settings now I have not found such an item. (For example, not 16.2 and 16.0)
Re: Add the ability to enter the volume with numbers on the keyboard
Scroll wheel uses the same step as keyboard shortcut and it can be changed in File->Preferences->Advanced->Playback->Volume step (you can set as low as 0.01 dB)
I tried this option, it does not fit. There is no binding to integers, if you move the slider with the mouse, the numbers become with a point and the wheel changes with a point.
Is there an option to change the volume only in whole numbers, without a comma? If not, is it possible to add such an option to the new version?
I opened another topic on the same issue. This topic can be deleted.
