Topic: Soundcard noise floor (Read 3324 times) previous topic - next topic
Hello,
I'm looking for a new soundcard because i'm constrained to put a -20dB resitive lpad on my loudspeakers inputs in order to lower the loudpeakers NF under the room NF.
It is not really a problem, my amps are very cheap and the lpad is a good counter-electromotive force eater...  ::)  but if anyone knows a soundcard with an awesome NF, i will be pleased to know it !
Re: Soundcard noise floor
What is your room NF?
DAC noise is mostly limited by the recording, all are well below 16 bit theoretical noise.
So basically you have 20dB too much gain and are loading the circuit with an iPad (headphone jack?) To lower the gain? If buying an amp with less gain isn't cost effective, I would buy an attenuator to replace the iPad.
Why do you need a sound card with a lower noise floor? Combined with the 20dB attention, almost any sound card should be fine.
28-30dB in the night and 45-48dB in the journey, but the there is an audible hiss only when i play a song on foobar or audacity.
I'm using an USB soundcard with equalizer APO, my amplifiers have a 24dB gain with around 120┬ÁV of noise, the attenuation is fine but i'm wasting energy.
Sorry for my english, i was hurry to prepare the dinner.
I've created a silent WAV file, tried to play it on foobar and the hiss is still there when i play the file, but there is no hiss at all when i don't.
Do you think that the problem is software? hardware? both?
It is the sound interface (hardware) only prosumer interfaces are silent.
what is prosumer and what isn't?
I think I have met some hardware which is pretty much silent, but would not be usually categorized as prosumer.
if your speakers are connected by a wire and not digitally, and there's hiss only when something is played, then the sound card is to blame (DAC, and/or any amplifier that's directly controlled by it).
good DACs aren't expensive, if you don't need a powerful amplifier with it. if your loudspeakers have their own amplifier, any cheap sound card will do that doesn't hiss and catch interference. which is pretty easy to test, if you don't hear any garbage when playing silence on this sound card, then it's good to go.
some ANC'd headphones + AutoEq-based impulse + Meier Crossfeed (30%)
I don't have a recommendation for you.
It gets tricky because the noise often gets into the soundcard from the computer's electronics and a particular soundcard may be better or worse in a different computer.   That my be why you get more noise when your computer is "doing something" like playing a silent file.    I read something recently where someone was getting noise when they move the mouse.
You can try an inexpensive USB soundcard.  That gets the soundcard away from the electrically-noisy internal computer electronics.   I have one like this that I got for "troubleshooting purposes" and it's "dead silent" with headphones on my laptop.    Noise can still get into a USB soundcard through the USB power but playback is usually less of a problem than recording.
Or, you can get a higher-end USB Audio Interface.     With USB-powered interfaces you can still get noise through the USB power, but again this is more of a problem with recording because the noise can get amplified by the microphone preamp..
I talk for those that don't have any resistive padding between all the impedances adaptations before the amplifiers ouputs (digital filtering), it is not so easy to find a silent sound interface in the consumer market (it is very hard) and the professionnal ones are the safe bet (but not all)
There is a lot to unpack there.  What are you trying to say?
This is not my experience.
Not mine as well. I get no audible noise from all of my Android-based phones 3.5mm jack. Also no audible noise from all outputs of an external soundcard Steinberg UR12, which is a cheap card (at least if you count that it can be used to record and monitor a guitar; the main purpose why I got it in the first place), I'm pretty sure that if you don't need recording, there are easily even cheaper solutions that work just as fine.
I need at last 4 ouputs, and the steinberg despite her "audiophools" capacitors don't perform extremely well at measurements :
https://translate.google.com/translate?hl=fr&sl=ru&tl=en&u=http%3A%2F%2Fprosound.ixbt.com%2Finterfaces%2Fsteinberg-ur22mk2.shtml&sandbox=1
It discouraged me to test this brand, i'm perhaps wrong.
What exactly isn't extremely well in measurements? -78.2 dB of distortion+noise, that's what they call "average" (other things they consider better, so let's focus on this one), is it something that human ear can hear? and is it a measurement of outputs or inputs or both? it seems it could be the latter, in that case in isolation the outputs must perform a lot better.
It is just rightmark numbers, i don't really trust them, also don't know if the steinbergs are good or bad and if the audiophile capacitors with their high end output operational amplifiers can help to judge.
I've taken an Presonus because i've tested one model and it is awesomely silent.
That link shows a noise floor 100dB below peak. That is literally orders of magnitude better than you need. If that is all you care about just buy that device.
Differences in quality don't matter if in both cases the total amount of distortion (all things that worsen the signal, combined) are totally out of reach of human hearing.
If you don't trust measurements, then what's the point of bringing them up btw?
is there even a definition of "audiophile capacitors"?
IMO it's best to ignore that as a meaningless detail.
Who can believe that a single number can substitute a complete measurement procedure with some graphs and their technical analysis... sales managers or supermarket buyers perhaps ?
Here is a interface with good measurements :
https://translate.google.com/translate?hl=fr&sl=ru&tl=en&u=http%3A%2F%2Fprosound.ixbt.com%2Finterfaces%2Fesi-gigaport-hd.shtml&sandbox=1
I've got that interface, the NF is one of the worse of all my interfaces, even entry level ones (professionnal).
is there even a definition of "audiophile capacitors"? IMO it's best to ignore that as a meaningless detail.
The expensive output buffer is taylored for a very low NF and the NF is not better than a cheap one, IMO it is not the most cost effective possible design.
Why don't put the money in a better USB bridge or better DACs (because this interface must be fullly compatible with I-things from Apple inc)
PS : audiophile capacitors definition : gold colored casing capacitors with a very high price tag and a low life expectancy that perform worse than some good standard capacitors.
I don't understand what that means either...
There's nothing special about capacitors with audio.   Audio is "easy".  Audio only goes up to about 20kHz (low/slow for electronics) and it's low voltage.    Capacitor values usually aren't super-critical for audio either.   The engineer might calculate a minimum of 1uF and then specify a 4.7uF capacitor.  (There's little, if any, cost difference.)   Or, maybe there are 10uF capacitors elsewhere on the board so he decides to make purchasing & assembly easier by specifying 10uF capacitors "everywhere".
"Why put an expensive capacitor if a cheap one perform better"
Noise floor is a single number, and it is what you asked about, so I am not sure where you are going with this. If you don't care about it, then why do you keep talking about it?
Are you saying that you don't think 100dB was enough? That is better than the intrinsic noise floor of CD audio. If you think you're hearing noise below what even your recordings can contain, you are doing something wrong.
Explain what you are doing and what the problem you have is.
If you increase volume up to eleven, don't you hear some  noise?
I don't think anything, just see that the measurements are inaccurate and don't match reality. So, i've solved the problem with a better interface, happy end.
It works only if you have a volume control (i don't have), you should raise the quality of your jokes, especially in the area of the context please (see Reply #8)
I really don't get it, which part of your setup is without a volume control? Soundcard or Windows or amp? :D
I can't speak to the accuracy of those specific measurements, but they're very typical, and you could find 100 devices that really do have that performance.  I don't think your skepticism is well founded.
Is this the same problem you were posting about above?  So you've solved whatever you were asking about?
why don't you also raise the quality of your threads then.
