Topic: Foobar 1.4.4 "not responding" after quitting (Read 234 times) previous topic - next topic
Please help me to diagnose this problem
Any clues are appreciated.
Foobar 1.4.4 "not responding" after quitting using method
File > Exit
or
X close
I have tried
  • removing all components
  • removing and reinstalling foobar2000
  • running as administrator
Core (2019-05-06 13:05:24 UTC)
    foobar2000 core 1.4.4
foo_albumlist.dll (2019-05-06 13:04:46 UTC)
    Album List 4.6
foo_cdda.dll (2019-05-06 13:04:50 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2019-05-06 13:04:50 UTC)
    Converter 1.5.3
foo_dsp_eq.dll (2019-05-06 13:04:40 UTC)
    Equalizer 1.2.1
foo_dsp_std.dll (2019-05-06 13:04:40 UTC)
    Standard DSP Array 1.3.2
foo_fileops.dll (2019-05-06 13:04:46 UTC)
    File Operations 2.3
foo_freedb2.dll (2019-05-06 13:04:46 UTC)
    Online Tagger 0.7
foo_input_std.dll (2019-05-06 13:05:16 UTC)
    FFmpeg Decoders 3.4.5
    Standard Input Array 1.4.4
foo_rgscan.dll (2019-05-06 13:04:48 UTC)
    ReplayGain Scanner 2.3
foo_ui_columns.dll (2019-06-06 23:04:32 UTC)
    Columns UI 1.0.0
foo_ui_std.dll (2019-05-06 13:04:56 UTC)
    Default User Interface 1.4.4
foo_unpack.dll (2019-05-06 13:04:54 UTC)
    ZIP/GZIP/RAR Reader 1.8
foo_upnp.dll (2019-06-01 18:35:59 UTC)
    UPnP/DLNA Renderer, Server, Control Point 0.99.49
Log Name:      Application
Source:        Application Hang
Date:          2019-Jun-06 19:33:11
Event ID:      1002
Task Category: (101)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      BPKLF180.agfahealthcare.com
Description:
The program foobar2000.exe version 1.4.4.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
 Process ID: 2128
 Start Time: 01d51cbf81cca484
 Termination Time: 60000
 Application Path: C:\Program Files (x86)\foobar2000\foobar2000.exe
 Report Id: 43a77125-88b3-11e9-9165-c966eb404eab
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Hang" />
    <EventID Qualifiers="0">1002</EventID>
    <Level>2</Level>
    <Task>101</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2019-06-06T23:33:11.000000000Z" />
    <EventRecordID>356432</EventRecordID>
    <Channel>Application</Channel>
    <Computer>BPKLF180.agfahealthcare.com</Computer>
    <Security />
  </System>
  <EventData>
    <Data>foobar2000.exe</Data>
    <Data>1.4.4.0</Data>
    <Data>2128</Data>
    <Data>01d51cbf81cca484</Data>
    <Data>60000</Data>
    <Data>C:\Program Files (x86)\foobar2000\foobar2000.exe</Data>
    <Data>43a77125-88b3-11e9-9165-c966eb404eab</Data>
    <Binary>55006E006B006E006F0077006E0000000000</Binary>
  </EventData>
</Event>
Source:        Windows Error Reporting
Date:          2019-Jun-06 19:32:01
Event ID:      1001
Task Category: None
Level:         Information
Keywords:      Classic
User:          N/A
Description:
Fault bucket 19560119, type 398677260
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: foobar2000.exe
P2: 1.4.4.0
P3: 5cd03111
P4: e16d
P5: 0
P6:
P7:
P8:
P9:
P10:
D:\Users\awuiz\AppData\Local\Temp\WER445A.tmp.appcompat.txt
D:\Users\awuiz\AppData\Local\Temp\WER4526.tmp.WERInternalMetadata.xml
These files may be available here:
D:\Users\awuiz\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppHang_foobar2000.exe_fb5ba2baecf6044838df2aed375add26b879_13a050f8
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
Event Xml:
  <System>
    <Provider Name="Windows Error Reporting" />
    <EventID Qualifiers="0">1001</EventID>
    <Level>4</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2019-06-06T23:32:01.000000000Z" />
    <EventRecordID>356430</EventRecordID>
    <Security />
  </System>
  <EventData>
    <Data>19560119</Data>
    <Data>398677260</Data>
    <Data>AppHangB1</Data>
    <Data>Not available</Data>
    <Data>0</Data>
    <Data>5cd03111</Data>
    <Data>e16d</Data>
    <Data>0</Data>
    <Data>
    </Data>
    <Data>
    </Data>
    <Data>
    </Data>
    <Data>
    </Data>
    <Data>
    </Data>
    <Data>
D:\Users\awuiz\AppData\Local\Temp\WER4526.tmp.WERInternalMetadata.xml</Data>
    <Data>D:\Users\awuiz\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppHang_foobar2000.exe_fb5ba2baecf6044838df2aed375add26b879_13a050f8</Data>
    <Data>
    </Data>
    <Data>0</Data>
    <Data>0</Data>
  </EventData>
</Event>
REPORT.WER
Version=1
EventType=AppHangB1
EventTime=132043375138221252
ReportType=3
Consent=1
UploadTime=132043375180111252
ReportIdentifier=43a77124-88b3-11e9-9165-c966eb404eab
IntegratorReportIdentifier=43a77125-88b3-11e9-9165-c966eb404eab
WOW64=1
Response.BucketId=19560119
Response.BucketTable=398677260
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=foobar2000.exe
Sig[1].Name=Application Version
Sig[1].Value=1.4.4.0
Sig[2].Name=Application Timestamp
Sig[2].Value=5cd03111
Sig[3].Name=Hang Signature
Sig[3].Value=e16d
Sig[4].Name=Hang Type
Sig[4].Value=0
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.4
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Hang Signature 1
DynamicSig[22].Value=e16d7162077e6de066c2c5b09f304b08
DynamicSig[23].Name=Additional Hang Signature 2
DynamicSig[23].Value=9af5
DynamicSig[24].Name=Additional Hang Signature 3
DynamicSig[24].Value=9af5fd6c85cffb166cbc9f020853a605
DynamicSig[25].Name=Additional Hang Signature 4
DynamicSig[25].Value=e16d
DynamicSig[26].Name=Additional Hang Signature 5
DynamicSig[26].Value=e16d7162077e6de066c2c5b09f304b08
DynamicSig[27].Name=Additional Hang Signature 6
DynamicSig[27].Value=9af5
DynamicSig[28].Name=Additional Hang Signature 7
DynamicSig[28].Value=9af5fd6c85cffb166cbc9f020853a605
UI[3]=foobar2000 is not responding
UI[4]=If you close the program, you might lose information.
UI[5]=Close the program
UI[6]=Close the program
UI[7]=Close the program
LoadedModule[0]=C:\Program Files (x86)\foobar2000\foobar2000.exe
LoadedModule[1]=C:\windows\SysWOW64\ntdll.dll
LoadedModule[2]=C:\windows\syswow64\kernel32.dll
LoadedModule[3]=C:\windows\syswow64\KERNELBASE.dll
LoadedModule[4]=C:\windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24440_none_2b1c5296457b2f0c\COMCTL32.dll
LoadedModule[5]=C:\windows\syswow64\msvcrt.dll
LoadedModule[6]=C:\windows\syswow64\GDI32.dll
LoadedModule[7]=C:\windows\syswow64\USER32.dll
LoadedModule[8]=C:\windows\syswow64\ADVAPI32.dll
LoadedModule[9]=C:\windows\SysWOW64\sechost.dll
LoadedModule[10]=C:\windows\syswow64\RPCRT4.dll
LoadedModule[11]=C:\windows\syswow64\SspiCli.dll
LoadedModule[12]=C:\windows\syswow64\CRYPTBASE.dll
LoadedModule[13]=C:\windows\syswow64\LPK.dll
LoadedModule[14]=C:\windows\syswow64\USP10.dll
LoadedModule[15]=C:\windows\syswow64\SHLWAPI.dll
LoadedModule[16]=C:\windows\system32\WINMM.dll
LoadedModule[17]=C:\windows\system32\DSOUND.dll
LoadedModule[18]=C:\windows\syswow64\ole32.dll
LoadedModule[19]=C:\windows\system32\POWRPROF.dll
LoadedModule[20]=C:\windows\syswow64\SETUPAPI.dll
LoadedModule[21]=C:\windows\syswow64\CFGMGR32.dll
LoadedModule[22]=C:\windows\syswow64\OLEAUT32.dll
LoadedModule[23]=C:\windows\syswow64\DEVOBJ.dll
LoadedModule[24]=C:\windows\system32\UxTheme.dll
LoadedModule[25]=C:\windows\syswow64\SHELL32.dll
LoadedModule[26]=C:\Program Files (x86)\foobar2000\zlib1.dll
LoadedModule[27]=C:\Program Files (x86)\foobar2000\shared.dll
LoadedModule[28]=C:\windows\syswow64\imagehlp.dll
LoadedModule[29]=C:\windows\system32\dbghelp.dll
LoadedModule[30]=C:\windows\syswow64\COMDLG32.dll
LoadedModule[31]=C:\Program Files (x86)\foobar2000\MSVCP140.dll
LoadedModule[32]=C:\Program Files (x86)\foobar2000\VCRUNTIME140.dll
LoadedModule[33]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-runtime-l1-1-0.dll
LoadedModule[34]=C:\Program Files (x86)\foobar2000\runtime\ucrtbase.DLL
LoadedModule[35]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-core-timezone-l1-1-0.dll
LoadedModule[36]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-core-file-l2-1-0.dll
LoadedModule[37]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-core-localization-l1-2-0.dll
LoadedModule[38]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-core-synch-l1-2-0.dll
LoadedModule[39]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-core-processthreads-l1-1-1.dll
LoadedModule[40]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-core-file-l1-2-0.dll
LoadedModule[41]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-string-l1-1-0.dll
LoadedModule[42]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-heap-l1-1-0.dll
LoadedModule[43]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-stdio-l1-1-0.dll
LoadedModule[44]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-convert-l1-1-0.dll
LoadedModule[45]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-locale-l1-1-0.dll
LoadedModule[46]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-math-l1-1-0.dll
LoadedModule[47]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-multibyte-l1-1-0.dll
LoadedModule[48]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-time-l1-1-0.dll
LoadedModule[49]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-filesystem-l1-1-0.dll
LoadedModule[50]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-environment-l1-1-0.dll
LoadedModule[51]=C:\Program Files (x86)\foobar2000\runtime\api-ms-win-crt-utility-l1-1-0.dll
LoadedModule[52]=C:\windows\system32\MSIMG32.dll
LoadedModule[53]=C:\windows\system32\OLEACC.dll
LoadedModule[54]=C:\windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.24440_none_5c07457ba00da8da\gdiplus.dll
LoadedModule[55]=C:\windows\syswow64\CRYPT32.dll
LoadedModule[56]=C:\windows\syswow64\MSASN1.dll
LoadedModule[57]=C:\windows\system32\WINHTTP.dll
LoadedModule[58]=C:\windows\system32\webio.dll
LoadedModule[59]=C:\windows\system32\Secur32.dll
LoadedModule[60]=C:\windows\system32\IMM32.DLL
LoadedModule[61]=C:\windows\syswow64\MSCTF.dll
LoadedModule[62]=C:\Program Files (x86)\foobar2000\components\foo_converter.dll
LoadedModule[63]=C:\Program Files (x86)\foobar2000\components\foo_freedb2.dll
LoadedModule[64]=C:\Program Files (x86)\foobar2000\components\foo_albumlist.dll
LoadedModule[65]=C:\Program Files (x86)\foobar2000\components\foo_unpack.dll
LoadedModule[66]=D:\Users\awuiz\AppData\Roaming\foobar2000\user-components\foo_upnp\foo_upnp.dll
LoadedModule[67]=C:\windows\system32\IPHLPAPI.DLL
LoadedModule[68]=C:\windows\syswow64\NSI.dll
LoadedModule[69]=C:\windows\system32\WINNSI.DLL
LoadedModule[70]=C:\windows\syswow64\WS2_32.dll
LoadedModule[71]=D:\Users\awuiz\AppData\Roaming\foobar2000\user-components\foo_ui_columns\foo_ui_columns.dll
LoadedModule[72]=C:\windows\syswow64\urlmon.dll
LoadedModule[73]=C:\windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll
LoadedModule[74]=C:\windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
LoadedModule[75]=C:\windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
LoadedModule[76]=C:\windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
LoadedModule[77]=C:\windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
LoadedModule[78]=C:\windows\system32\version.DLL
LoadedModule[79]=C:\windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
LoadedModule[80]=C:\windows\syswow64\normaliz.DLL
LoadedModule[81]=C:\windows\syswow64\iertutil.dll
LoadedModule[82]=C:\windows\syswow64\WININET.dll
LoadedModule[83]=C:\windows\syswow64\USERENV.dll
LoadedModule[84]=C:\windows\syswow64\profapi.dll
LoadedModule[85]=C:\Program Files (x86)\foobar2000\components\foo_dsp_std.dll
LoadedModule[86]=C:\Program Files (x86)\foobar2000\components\foo_input_std.dll
LoadedModule[87]=C:\windows\system32\MSACM32.dll
LoadedModule[88]=C:\Program Files (x86)\foobar2000\avcodec-fb2k-57.dll
LoadedModule[89]=C:\Program Files (x86)\foobar2000\avutil-fb2k-55.dll
LoadedModule[90]=C:\Program Files (x86)\foobar2000\components\foo_rgscan.dll
LoadedModule[91]=C:\Program Files (x86)\foobar2000\components\foo_cdda.dll
LoadedModule[92]=C:\Program Files (x86)\foobar2000\components\foo_dsp_eq.dll
LoadedModule[93]=C:\Program Files (x86)\foobar2000\components\foo_ui_std.dll
LoadedModule[94]=C:\Program Files (x86)\foobar2000\components\foo_fileops.dll
LoadedModule[95]=C:\windows\syswow64\CLBCatQ.DLL
LoadedModule[96]=C:\windows\System32\MMDevApi.dll
LoadedModule[97]=C:\windows\System32\PROPSYS.dll
LoadedModule[98]=C:\windows\system32\AUDIOSES.DLL
LoadedModule[99]=C:\windows\system32\WindowsCodecs.dll
LoadedModule[100]=C:\windows\system32\apphelp.dll
LoadedModule[101]=D:\Users\awuiz\AppData\Local\Microsoft\OneDrive\19.070.0410.0007\FileSyncShell.dll
LoadedModule[102]=C:\windows\system32\ktmw32.dll
LoadedModule[103]=C:\windows\syswow64\PSAPI.DLL
LoadedModule[104]=C:\windows\system32\EhStorShell.dll
LoadedModule[105]=C:\windows\system32\ntshrui.dll
LoadedModule[106]=C:\windows\system32\srvcli.dll
LoadedModule[107]=C:\windows\system32\cscapi.dll
LoadedModule[108]=C:\windows\system32\slc.dll
LoadedModule[109]=C:\windows\System32\sud.dll
LoadedModule[110]=C:\windows\System32\ADVPACK.dll
LoadedModule[111]=C:\windows\System32\DUI70.dll
LoadedModule[112]=C:\windows\system32\mswsock.dll
LoadedModule[113]=C:\windows\System32\wshtcpip.dll
LoadedModule[114]=C:\windows\system32\dhcpcsvc.DLL
LoadedModule[115]=C:\windows\system32\explorerframe.dll
LoadedModule[116]=C:\windows\system32\DUser.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
State[1].Key=DataRequest
State[1].Value=Bucket=19560119/nBucketTable=398677260/nResponse=1/n
FriendlyEventName=Stopped responding and was closed
ConsentKey=AppHangXProcB1
AppName=foobar2000
AppPath=C:\Program Files (x86)\foobar2000\foobar2000.exe
ReportDescription=A problem caused this program to stop interacting with Windows.
Re: Foobar 1.4.4 "not responding" after quitting
I don't see any unwanted dlls and since it happens with a clean install the regular thread list won't be enough to debug this.
Can you provide a memory dump of the frozen process so Peter can take a look? Instructions can be found here.
Per your request, I have uploaded the dump.
I have traced the problem specifically to component foo_upnp
I get the same "not responding" behavior when I attempt to stop the renderer or server
I have foobar2000 1.4.5 and foo_upnp 0.99.49
Hello.
I recently updated to 1.4.4. and have the same issue; Foobar not responding on exit almost every time.
However I don't use the upnp server component.
Also noticed lag with forward/rewind 5sec in tracks,
& using visualisation/analysers It skips/stutters a few secs before its normal fluid again.
I've just rolled back, re-installed 1.4.3.
Sorry I can't clarify the issue more, I'm not that technical.
Just reporting same/similar issue regarding 1.4.4 update.
