Topic: A search code value for radio stream track metadata? (Read 688 times) previous topic - next topic
When Foobar plays a stream sending track metadata, artist and title appear in the status bar (and playlist) in the normal way, changing dynamically as the track changes.  However attempting to use the usual %artist% and %title% in a web search expression on a current track with a tool like Run Services will fail, as it attempts to pull those values out of the station's fixed "tag" value in Foobar which of course does not match.  Is there a certain value that can be substituted in a case like this that will get artist and title values out of the dynamic metadata at the time?  Am used to doing those kind of searches with a couple of other players (MusicBee, and AIMP with its "Open With" plugin) and it would be great to be able to do them in Foobar as well.
Re: A search code value for radio stream track metadata?
You can try a quick dirty hacky component www.saunalahti.fi/~cse/temp/foo_dyndec.fb2k-component. It exposes the dynamically changing fields you need in %dartist% and %dtitle%. Probably best to use with some if function wrapping, something like $if2(%dtitle%,%title%).
Edit 2020-01-26: Removed the old temp link. The component is now located at http://www.foobar2000.org/components/view/foo_dyndec
Case, you're a miracle worker, THANKS for this!  Just the %dartist% and %dtitle% seem to work fine on their own by changing the nominal %artist% and %title% in the Run Services expression.  Furthermore, it doesn't effect the search working the same way on a PLAYING regular file instead of a stream.  If the file was not being played, one would probably need to use your example of $if2(%dtitle%,%title%) in the right fields for the variable code to work.
I listen to a lot of Internet radio, and when a song comes on I'm curious about, with foo_dyndec I NOW can use Run Services to perform a search on the playing track's artist, or artist + song, at various sites.  Surely, this will be useful to many other Foobar users as well?!  Just to get someone started, here's two Run Services entries that will search a playing radio stream's metadata at the Metal Archives website:
Metal Archives Artist (dyn)
https://www.metal-archives.com/search?searchString=$replace(%dartist%, ,+)&type=band_name
Metal Archives Artist + Title (dyn)
https://www.metal-archives.com/search/advanced/searching/songs?songTitle=$replace(%dtitle%, ,+)&bandName=$replace(%dartist%, ,+)&releaseTitle=&lyrics=&genre=#songs
Sir, this is the best plugin I've discovered in a long time!  Thanks again.
Case, sveakul, thank you very much!
for me this feature is also useful. That looks like - must have!
Thank you very much Case for this clean hacky component!  A long time I was looking for this feature for a radio stream sending track metadata with Run Services!
