Topic: flac overwriting existing files, while ffmpeg does not (Read 2069 times) previous topic - next topic
So, a while ago I put together a set of scripts to convert stuff into .flac with my preferred settings. But I learned that libflac is quite a bit more efficient than ffmpeg's Lavf58.
Took a gander at flac's manpage, picked out the options that I (think) resemble what I did with ffmpeg, and go to test.
For use with ffmpeg, I set up 2 scripts, an init one and a worker script. The init basically just starts as many workers as there are cores on the system. Now when I replace my ffmpeg command with the flac one, flac starts to overwrite and (presumably) write into files created by other worker processes. Is flac already multithreaded to begin with?
Some info: the init and worker script running on Manjaro Linux, using flac 1.3.2-2
pacman -Si flac
Repository      : extra
Version         : 1.3.2-2
Description     : Free Lossless Audio Codec
Architecture    : x86_64
URL             : http://flac.sourceforge.net/
Licenses        : BSD  GPL
Groups          : None
Provides        : None
Depends On      : gcc-libs  libogg
Optional Deps   : None
Conflicts With  : None
Replaces        : None
Download Size   : 376,21 KiB
Installed Size  : 1332,00 KiB
Packager        : Evangelos Foutras <evangelos@foutrelis.com>
Build Date      : Sa 10 Nov 2018 00:18:08 CET
Validated By    : MD5 Sum  SHA-256 Sum  Signature
Re: flac overwriting existing files, while ffmpeg does not
Barring some race condition, flac should exit/continue with next file if the destination file already exists.
Btw, are you sure you want to use --force-raw-format option?
Unless I'm misunderstanding, since you've hard coded the path, I think you are telling all workers to transcode the same file.  Probably you want to either give each worker a different list of files, or have the first worker do file 1, 5, 9 ...
In addition to forcing raw when you don't have raw files, your script looks for MP4 files but you never actually call an MP4 decoder.
I believe OP is counting on the fact that only one worker will actually start encoding a given file while others will get error that the destination already exists and they will try with the next file.
