Does redmi note 7 pro is hi-fi audio compliant or not. 2019-06-03 14:59:10 Hi I am Rupesh from India and at present I am using redmi note 4 with 64 GB and snapdragon processor ie., mido. I want to buy a new smartphone which provides high quality audio ie., which has separate component for audio processing.Two years back I thought to buy a new smartphone which has separate component for audio processing and found that mi note series smartphones have separate component for audio processing and I have brought redmi note 4.At present I am searching for a new smartphone which has separate component for audio processing and so I have examined the specifications of redmi note 7 pro and unfortunately I found that it does not have separate component for audio processing I mean it is not hifi audio compliant.At present I have also searched for other smartphone which has separate component for audio processing and found a smartphone named zte axon mini ion gold. This particular phone is very affordable.I would like to buy redmi note 7 pro happily if it is hifi audio compliant. Can anyone of you suggest any other smartphone which is hifi compliant and at the same time affordable.Please examine the following links and also examine the specifications of redmi note 7 pro and confirm whether it is hifi audio compliant or not.https://www.mi.com/global/minote/hifi/https://www.amazon.in/ZTE-AXON-Mini-ion-Gold/dp/B01L1TVH14Regards,Rupesh.
Re: Does redmi note 7 pro is hi-fi audio compliant or not. Reply #1 – 2019-06-04 05:29:21 "separate component for audio processing" means what exactly? Anyway, no one is going to be able to tell you much about that phone from those links. Why don't you look to see if any reviewers have tested the audio output? Most likely it is fine since there is rarely any difference between phones though.
Re: Does redmi note 7 pro is hi-fi audio compliant or not. Reply #2 – 2019-06-04 09:43:07 An example of a review: https://www.audiosciencereview.com/forum/index.php?threads/review-and-audio-measurement-of-lg-g7-thinq-smartphone.4468/
Re: Does redmi note 7 pro is hi-fi audio compliant or not. Reply #3 – 2019-06-08 06:22:03 Please visit the following thread which is created by myself. I have created that thread separately because I thought many people may benefited.https://hydrogenaud.io/index.php/topic,117740.new.html#newLG Q7+TM has DTS: X feature. Does this smartphone has any DAC, amp. Last Edit: 2019-06-08 06:24:16 by rupeshforu3
