Topic: Syntax: Return value in list unless it matches specified value?  (Read 149 times) previous topic - next topic
Hi all, I'm wondering if this can be done in foobar2000, I'm assuming it can given that the syntax is quite powerful but I haven't been able to figure it out.
I use Facets and want to create a column query that returns a list of values except for when it matches a specified value (or multiple specified values).
That might sound confusing so I'll give some examples:
1. I have a label tag and want a list of labels, so I currently have [%label%]. However, I don't want it to show the tag Self-Released in the list, the same way it won't show results with no label set.
2. I have a genre column ([%genre%]) and want to exclude certain general genres from the list. So I might not want to show, as an example, Spoken Word or Interview.
I'm hoping there's a syntax that can do this by the column. I know I could use filters in the case of Facets but I'm assuming there's a syntax that can do it which would be my preferred solution.
I have a hunch that something involving $if($strstr... might work just from that string being used in a theme I use.
Re: Syntax: Return value in list unless it matches specified value?
Answer from IRC for Case 1:
$if($stricmp(%label%,Self-Released),,[%label%])
Answer from IRC for Case 2:
[$if($strstr(;spoken word;interview;,;$lower(%genre%);),,%<genre>%)]
