Topic: system crashes and the fpl's in the config folder. (Read 110 times) previous topic - next topic
Because of system crashes, as far a I can tell, unrelated to foobar, I've found it necesary to copy the playlist files in the config folder and try to recover something from there. I also used the "previous versions" tab in folder properties to find earlier copies of the files just in case.
The problem is when I try to load any of those (having first copied them somewhere else), foobar can't seem to properly load them, but just what I suppose is the first entry of the playlist, reporting this error.
The following error(s) occurred during loading of the location(s):
Unsupported format or corrupted file
Is this to be expected? Am I doing something wrong?
