Topic: CUERipper 2.1.6: where are output path templates saved ? (Read 1802 times) previous topic - next topic
Hi all,
in CUERipper 2.1.6 I can define additional output path templates and they work fine.
However, clicking on the field I see all the default templates plus the ones I have reated.
I'd like to see only the ones I have defined: are they stored in some .ini / config file I can edit ?
Thanks !
Re: CUERipper 2.1.6: where are output path templates saved ?
The settings.txt file is either located in %appdata%\CUERipper or if you are running as portable (you deleted the user_profiles_enabled file) it will be in \CUETools_2.1.6\CUERipper
but I don't think you can remove the default templates
korth
Thx !
