Topic: 1.4.4 crashes (Read 1096 times) previous topic - next topic
1.4.4 crashes
I'm getting frequent crashes since I updated to 1.4.4.
What is strange is that I'm using 2 copies of portable FB - both have the same version, DUI layout, components and setup.
Only one is crashing - it has my master library (1.76TB). The other is used for preview library (<20GB) and has not crashed at all.
There does not seem to be a trigger - the crashes happen randomly when playing. (e.g. select a few albums via SIMPlaylist, play (shuffle tracks) and a few songs in, it will crash)
The most recent crash (laptop was only being used to play music, no other activities):
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   foobar2000.exe
  Application Version:   0.0.0.0
  Application Timestamp:   5cd03111
  Fault Module Name:   ntdll.dll
  Fault Module Version:   6.1.7601.24441
  Fault Module Timestamp:   5cb937ce
  Exception Code:   c0000006
  Exception Offset:   00063289
  OS Version:   6.1.7601.2.1.0.768.3
  Locale ID:   1033
  Additional Information 1:   abcc
  Additional Information 2:   abcc8f7853b48d9807d6d51eb1fa5df9
  Additional Information 3:   abcc
  Additional Information 4:   abcc8f7853b48d9807d6d51eb1fa5df9
This is the most useful ntdll.dll lead that I've found, but not particularly helpful:
https://answers.microsoft.com/en-us/windows/forum/windows_7-performance/problem-registering-a-dll-with-command-prompt/44ebc140-9b8c-4120-a3d5-06d61cf68377?tab=AllReplies#tabs
I'm using win7 64-bit, intel i5-2430CPU @ 2.4ghz, 16GB RAM, FB general RAM usage ~950MB.
appreciate any help!
Re: 1.4.4 crashes
https://stackoverflow.com/questions/1317886/external-exception-c0000006
https://superuser.com/questions/1084110/rdp-server-giving-c0000006-for-application-programs
That's EXCEPTION_IN_PAGE_ERROR. It means that the OS loader failed to page in some data required for the application to run, probably due to an I/O error or other error.
0xC0000006 errors arise when your program goes to page more data for the EXE into memory, but couldn't. Usually this is caused by an I/O issue when attempting to read the data.
Re: 1.4.4 crashes
another one
Problem signature:
  Fault Module Name:   VCRUNTIME140.dll
  Fault Module Version:   0.0.0.0
  Fault Module Timestamp:   5a39fdb6
  Exception Offset:   00003006
  Locale ID:   1033
  Additional Information 1:   6eb1
  Additional Information 2:   6eb16cc795a822986876575da7ae1c84
  Additional Information 3:   5cc4
  Additional Information 4:   5cc4027800328d0d1886389ba0b9ad0b
and yet another one...
Problem signature:
  Fault Module Name:   StackHash_478a
  Fault Module Timestamp:   00000000
  Exception Code:   c0000005
  Exception Offset:   74a7e514
  Locale ID:   1033
  Additional Information 1:   478a
  Additional Information 2:   478a8a0e64c8dc6af36ce664c40f7197
  Additional Information 3:   c599
  Additional Information 4:   c599a0fc431e10620d6e651af4016b80
Re: 1.4.4 crashes
Problem signature:
  Locale ID:   1033
frustrating as hell... dumping 1.44 now.
Re: 1.4.4 crashes
Thanks Case, that does make more sense.
The crashing copy has been running from the ext. HD, so I'll try and move it to my internal.
