Topic: what are HTOA flac files? (Read 2518 times) previous topic - next topic
When I take embedded flac files and extract the tracks, I usually end up with a file that looks like: artist - (HTOA).flac. My track format is: %artist% - %title%
Those HTOA flac files are around 22kB in size.  What are they?
Re: what are HTOA flac files?
Just a waste of disc space when they’re that small. ;)
The beginning of the first track doesn’t always start at 00:00:00. Cuetools will preserve any data from 00:00:00 up to the beginning of the first track even if it is just silence. Sometimes you might find actual content there which is why it is called Hidden Track One Audio (HTOA).
I think we have a wiki article on it. Search the wiki for the term and you should find out all you need to know. If you haven’t already seen it our wiki has a lot of good information and may save you from having to ask here.
Thanks for the response. I was looking through db.cuetools.net and ran across mention of it. I was coming back here to update my post, but you beat me to it. The result seems to be that they are useless and I will delete when I get them.
Dump them all into a media player and check the lengths. And if you are curious, scan them for peaks ... you will find out most are digital zero.
They are also a placeholder to preserve the original CD layout. Of course there are other ways to do that: pregap in CUE file, TOC file, TOC in extraction log, AccuraterRip metadata tags, CTDB metadata tags, CDTOC metadata tag.
See setting in CUETools to not write HTOA file.
http://cue.tools/wiki/CUETools_Advanced_Settings:_CUETools#Gaps_handling
korth
Thanks. Since there are zero plans to recreate CDs, the HTOA and gaps aren't needed. The extracted file will be for listening only via media players.
