Topic: Exact Audio Copy: File creation Error (Read 1594 times) previous topic - next topic
I'm so glad I found this Forum. Thank you in advance for any help with this:
I use EAC for years and never had any trouble with it. I didn't change anything to the settings, nor to the PC (except probably automated updates for Windows 10) and suddenly I get a "file creation error" each time I try to copy a CD. It does so always on the first track and aborts.
Here's the log:
Track  1
     Copy aborted
Track  2
     Copy aborted
Track  3
     Copy aborted
Track  4
     Copy aborted
Track  5
     Copy aborted
Track  6
     Copy aborted
Track  7
     Copy aborted
Track  8
     Copy aborted
Track  9
     Copy aborted
 1 track(s) not fully ripped for AccurateRip lookup
 8 track(s) canceled
No tracks could be verified as accurate
There were errors
End of status report
MOD EDIT: log in code box
Re: Exact Audio Copy: File creation Error
You did a search?
https://hydrogenaud.io/index.php/topic,115674.msg954405.html#msg954405
https://hydrogenaud.io/index.php/topic,112615.msg927955.html#msg927955
https://hydrogenaud.io/index.php/topic,65757.msg586823.html#msg586823
https://hydrogenaud.io/index.php/topic,97355.msg810831.html#msg810831
https://hydrogenaud.io/index.php/topic,109012.msg896589.html#msg896589
All CDs?
What are your settings for
EAC > EAC Options > Directories (tab)
EAC > EAC Options > Filename (tab) > Naming scheme
Can you post a full extraction log (see pic)?
korth
Make sure your CD has both a CD artist and album title otherwise EAC chokes making a file name.
Hi, thanks. I made sure it had these fields filled in, but to no avail, still "file creation error".
You did a search?
All CDs?
thank you for the search. I missed that- I'll have a look at them and report back.
You did a search?
All CDs?
So I went through these threads but couldn't find anything to relate to.
The settings are as follows:
EAC > EAC Options > Directories (tab): "Ask everytime (Default showing last used directory)
EAC > EAC Options > Filename (tab): %tracknr2% %title%
Here is the full extraction log:
Exact Audio Copy V1.3 from 2. September 2016
EAC extraction logfile from 27. May 2019, 10:15
Feldman, Caine, Cohen, Baron / Secrets
Used drive  : PIONEER BD-RW   BDR-209D   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 667
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Not detected, thus appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -6 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  6:27.62 |         0    |    29086
        2  |  6:27.62 |  5:42.07 |     29087    |    54743
        3  | 12:09.69 |  5:26.59 |     54744    |    79252
        4  | 17:36.53 |  4:12.29 |     79253    |    98181
        5  | 21:49.07 |  7:33.71 |     98182    |   132227
        6  | 29:23.03 |  3:26.55 |    132228    |   147732
        7  | 32:49.58 |  6:35.30 |    147733    |   177387
        8  | 39:25.13 |  5:38.42 |    177388    |   202779
        9  | 45:03.55 |  4:25.19 |    202780    |   222673
Track  1
     Filename F:\Music\-\etc\Tzadik\Radical Jewish Culture\TZ 8130 Secrets - Feldman, Caine, Cohen, Baron\01 Lubavitcher Nigun.wav
     Copy aborted
Track  2
     Filename F:\Music\-\etc\Tzadik\Radical Jewish Culture\TZ 8130 Secrets - Feldman, Caine, Cohen, Baron\02 Avinu Malkenu.wav
     Copy aborted
Track  3
     Copy aborted
Track  4
     Copy aborted
Track  5
     Copy aborted
Track  6
     Copy aborted
Track  7
     Copy aborted
Track  8
     Copy aborted
Track  9
     Copy aborted
 8 track(s) canceled
There were errors
All CDs?
Or just this one?
Unclear if you have a folder named "-", you edited something out or ...
I'd try shortening the path all the way down to "F:\Music"
You can always move the files if it rips.
korth
All CDs?
Or just this one?
All CDs suddenly. I didn't change anything for years in this setup and the settings but seemingly out of the blue it says "file creation error"
No this folder "-" exists (also for years - and works well)
I tried that. I also tried to move it to a different drive...
I also uninstalled it and installed it again. Could it be a Windows 10 update? Something with file permissions (I tried a few things but that too didn't help).
Did you also clear the registry settings?
HKEY_CURRENT_USER\Software\AWSoftware\EACU
Each plugin also has settings data saved in the registry in different locations but I wouldn't think they would matter.
I've had permission and sharing settings change after a version update.
You would receive the same type of error trying to save files to a location that the program doesn't have permission to write (like C:\) but you said you already tried saving to a different location.
korth
Permission seems to be the culprit. When I changed location, I still used the same drive. Now, I changed drive and it works. Now I have to figure out how to change permissions. "Run as administrator" doesn't help. Left click > properties and then enabling "Write" doesn't do anything either... Have to investigate
Do you know how to get the permissions right for EAC to work properly?
Thank you all for you help. Thanks korth for your advice with the permissions. I git it now working. I set permission at the root.
