Topic: Eole, a SMP/ColumnUI theme (Read 16075 times) previous topic - next topic
Re: Eole, a SMP/ColumnUI theme
Reply #100
Every time I scroll down to the bottom of my artist list, foobar crashes with an out of memory error.
I'm using foobar2000 1.5.2 and have 8GB's of ram.
I have 53 artists, 98 albums, and around 1200 songs.
Cool story bro.
Reply #101
Quick message to thank you for your work. This is a very fine and delicate skin.
PS : I've not bothered to change and adapt a foobar theme since a veryyy long time, and your work did motivate me. Congratulations!
Reply #102
And while I'm here a question arise: how to have more than 3 filters in library view?
I can create a new one successfully, but it always the place of one of the 3 originals (GENRE, ARTIST & ALBUM). So I can't add for instance a proper dedicated DATE filter without loosing something else.
Reply #103
Just installed Eole today - exact same thing happening to me.
"Error: Spider Monkey Panel v1.2.3 (GraphicBrowser v1.2.3.b14 by Ottodix)
Out of memory: 2454502/1073741824 bytes"
Keeps spitting out similar errors after I close each one.
Reply #104
Hello. I very like this theme. But i got an issue when group by genre. If Album tag by multi genre . I just can to show first genre or multi genre on the same line. Have any way to seperate each gerne to each line .
Sorry for my bad english.
Reply #105
Thanks for the superb skin. A couple of questions:
1) Can  you add a Playback order button available to the bottom bar "Visible buttons" selections?
2) How do you enter queue manager?
3) How to add a lyrics tab to the Library-Playlists-Now playing-Visualization bar?
4) This may be a bug (using 1.2.3 b14): Now playing and Visualization tabs are using using the light theme while in dark mode. I've used the dark/light switch exclusively.
Reply #106
Hey there, great theme, looks really clean. But I have a minor problem that i cant get to fix for some reason
The "Library" and "Playlists" dont have an enlarged Album Cover on the right side like the "Now playing" and "Visualization" tabs do. And sadly I dont have any idea on how to do anything with js. I also checked every Setting on the panels to try get that fixed but nothing helped.
Is there a way to activate that on those tabs or is it not supposed to be that way? Thanks!
Reply #107
There is quite a lot of post I didn't reply to...
Out of memory errors > Honestly, I don't know...
More than 3 filters > You can't !
Multi tags > they aren't supported by this theme
1) there is 2 buttons, one for repeat which cycle trough various options (the mouse tooltip will indicate the behavior of each option), one for shuffle. You can do everything with those 2 buttons, and otherwise, you can also do a right click any on the control bar.
2) by using a component like foo_playqueue manager
3) Sorry, too long to explain, it can't be done easily
4) The lightswitch button toggle between dark/light theme independently for each panel, it's the intended behavior
There is a button for that in the top bar, a icon which look like a little equalizer/spectrum visualizer (I was too lazy to make a new icon for this action, so it's not really appropriate. I'll do a new one later)
Reply #108
Hi.  Loving your work.  The only thing I can't figure out is a quick way to change output.  I like to use Wasapi (event), but if I want to change to Direct Sound I need to go Foobar>Library>Configure>Playback>Output>DS.
Is it possible to add a button in the top right that would list available outputs and allow selection?
Thanks for your hard work!!!
