Topic: A couple of questions about EAC (Read 1696 times) previous topic - next topic
Hi guys, I opened another thread to ask something about EAC etc. My first question is if there's any real benefit by activating the C2 error information mode. EAC says my drive is capable of retrieving C2 error information but I read here and on various forum on the web that maybe it's not a good choice. I'm a little confused. My current configuration is Secure Mode with accurate stream + test and copy to extract audio. Mine is a good choice?
Another questions is about "differs samples" in some tracks. I read that it could refer to some bad rips from users. I tried to listening at the point of samples and I don't hear any glitch ecc. This is my result:
Spoiler (click to show/hide)
"Always account for the change."
Re: A couple of questions about EAC
#9 could be that the CD had dodgy pressings ...
What do the AccurateRip figures say?
EAC can test if C2 capable but cannot tell you whether the C2 setting will be reliable.
http://wiki.hydrogenaud.io/index.php?title=EAC_Drive_Options#Drive_is_capable_of_retrieving_C2_error_information
Quote from: Linuxx
This section of the extraction results are from the CUETools Database Plugin for EAC
You should be looking at
  1   | (1862/1890) Accurately ripped
  2   | (1870/1890) Accurately ripped
  3   | (1868/1890) Accurately ripped
  4   | (1863/1890) Accurately ripped
  5   | (1873/1890) Accurately ripped
  6   | (1872/1890) Accurately ripped
  7   | (1869/1890) Accurately ripped
  8   | (1854/1890) Accurately ripped
  9   |  ( 24/1890) Accurately ripped
 10   | (1857/1890) Accurately ripped
and not worry about the "differs in" unless it doesn't say "Accurately ripped" or x is not greater than 1 (x/1890)
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: yDm0YkACmmd4RAS8_ZDfcWmkGN0-] found
Submit result: already submitted
a (1/1890) Accurately ripped result could be from your own previous rip
Quote from: Linuxx
Any "differs in" where x is not greater than 1 (x/1890) should be ignored as a probable bad rip. See plugin Known Issues.
The issue was fixed in newer versions of the plugin but some people are still using older versions of EAC with the old plugin.
Edit: cleaned up
korth
Yeah result was already added in database from my previous rip in mp3. Now I'm ripping in flac. I attach entire EAC log.
So I don't have to worry? My rip is perfect? And about C2 pointers even if EAC says it's supported can I keep it disabled? As in log, config is like this:
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : No
All tracks accurately ripped.
It is OK to disable use of C2 pointers.
korth
Thanks Korth! Very gentle!  :) A last question...I'm ripping in individual tracks and when I create the cue sheet file I get INDEX 00 for some album. Is it normal?
After read all which one should I choose? Current Gap Settings or Multiple WAV Files With Gaps (Noncompliant)?
With the default settings
Append Gaps to Previous Track (default)
either would produce the same CUE.
korth
Ok, now everything is clear! So I always did well to use "Multiple WAV Files With Gaps (Noncompliant)". Thank you again Korth for your patience!  ;)
If I'm not mistaken that will prevent you from using Cuetools and many other tools which expect a compliant cuesheet.
Personally I've always preferred to rip losslessly as an image (single .wav file + CUE) and eventually use Foobar2000 to split the tracks and compress them with LAME for usage on my portable devices, but of course YMMV...
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
CUETools can read a Noncompliant CUE sheet. CUETools and CUERipper will also create Noncompliant CUE sheets when the gap information is available.
Other programs that adhere to the cue sheet specification, like foobar2000 won't be able to read it.
korth
Oops! Sorry for spreading misinformation!
Sergio
@korth this is a good rip despite a lots of differ in samples?
That rip is good. All the "differ in samples" are 3 CTDB submissions. (They might very well be the same rip, but do not care about others' faulty rips - care about good ones.)
Ook! Thanks a lot for the answer! :)
And this time a log says "If you are sure that your rip contains errors, you can use CUETools to repair it." The last track has less feedback with accurate rips...
Should I assume that my rip is good or bad?
15   | (  6/208) Accurately ripped
good ["Accurately ripped" and for (x/nnn) x is > 1 ]. Your rip matches 6 others already in the CTDB database for your variant (pressing) of the CD. CTDB groups all pressings together so the higher numbers on other tracks are from other variants of the CD (pressings) that also match your rip.
What did AccurateRip say about the rip?
Look at your first post in this thread again. The CUETools DB Plugin for EAC always adds that when a recovery record exists that differs (differs in xx samples) from your rip.
korth
Just a little curiosity...Why last track matches only 6/208 while the others have 191/208?
AccurateRip stores each pressing separate. What did AccurateRip say about the rip?
see also
AccurateRip#Pressings
Your CD is a variant meaning all the data on your CD doesn't exactly match all the other pressings. It differs by 1 sample (you can't perceive one sample). Your rip does match others that ripped the same variant of the CD that you have.
korth
For example a cd remastered or different edition, right?
How long is the track? If 10:34:48 is at the very end ...
What does AccurateRip (not CTDB) say?
@Porcus Accurate rip is ok:
Track 15
     Filename C:\EAC Rips\M83 - Before The Dawn Heals Us\15. Lower Your Eyelids To Die With The Sun.wav
     Peak level 99.2 %
     Extraction speed 4.5 X
     Track quality 100.0 %
     Test CRC 7F4C2F0D
     Copy CRC 7F4C2F0D
     Accurately ripped (confidence 8)  [376FAAE5]  (AR v2)
     Copy OK
And yes, differs in samples is at the end of song, absolute silence.
Confidence 8, and the rest have ... higher or about the same?
It doesn't matter that much:
IDK about CUETools, but AccurateRip ignores the last five frames = 1/15th of the CD, for that reason. Depending on offset and overreading capabilities, some drives may start the "absolute silence" a little bit earlier. Here it could be one sample ... whoa, that sounds rare.
Things are complicated by different pressings (i.e. different write offsets, each master being written to CD with different offsets). Normally, five frames would be enough.
If you consistently get issues with the last track, try to have a look at overreading options. As long as it does not cut off the audio so early that actual music is lost, then you won't miss anything (I count one sample near-silence at the end as "nothing). But, it might fail to verify rips that are basically OK. (If there is not enough in the database, it won't tell you where and how big the error is; an inaccurate-and-nothing-more wouldn't tell you whether it is just the near-silence at the end, total corruption.)
Confidence 8 for all tracks. Anyway differs in samples at the end of last song is 100% on silence. The song ends with fading a few seconds before. So I think there isn't any problem.
