Topic: Is foobar's input udp-aware? (Read 194 times) previous topic - next topic
First post here, so apologies if this should be trivial or has been asked before:
Foobar is - as the only app I've found - able to play files consisting of raw AAC frames with ADTS headers (non-seekable though). The SDR qirx (I'm the author) is able to produce such files when tuned to a DAB+ broadcast station.
Question: Is foobar able to accept such frames from a network source e.g. via UDP, in a similar way the vlc player is able to do so with 16bit pcm samples?
