Topic: Copy full list of Artist Names? (Read 291 times) previous topic - next topic
Is it possible to copy the full list of Artist Names as seen in the first line of the Properties window of a selection?
It does not list all names of the selection, only approx 10 names, and ends with "..."
Any way to copy the full list?
thanks.
Re: Copy full list of Artist Names?
It does copy the full list in a format that's compatible with the Paste Fields feature in the Properties dialog, so you can select another (same number) set of files and paste the fields onto them. Unfortunately, it doesn't appear to support plaintext copying a useful list.
You could copy all artist names using Text Tools component. Then sort the list and remove duplicate entries in a text editor. This be done in Notepad++ using the TextFX plugin ( TextFX -> TextFX Tools -> Sort outputs only unique, Sort lines case sensitive ). In another text editor you may use Search & Replace with regular expressions to remove duplicate lines after sorting.
Thanks a bunch j7n.
As i needed a comma seperated list of all artists:
Copied full list with Text Tools,
Then using the TextFX plugin ( TextFX -> TextFX Tools -> Sort outputs only unique, Sort lines case sensitive ),
Then in replace window: Select "regular expressions" -> Find what "[\r\n]+" -> Replace with ", " -> Replace all.
Done.  Awsome. :)
