Topic: advice need on twin rad woofer build (Read 320 times) previous topic - next topic
im building my own version of the
Passive Dayton Audio Reference 15" With Dual Passive Radiator Subwoofer Kit
that has a Finished internal cabinet volume: 3.2 cubic feet
an is pair with twin 15in rads the Dayton Audio RSS390-PR 15" Aluminum Cone Passive Radiator
my question is does it have to be square to still work right with the rads
my design is flat but still is  3.2 cubic feet
with the rads a sub driver all on the same side in a rad - drive - rad orientation
would this still work
as iv never build a rad based design before only ported
my internal box specs are
width 16.9in
hight 47in
deep 7.25in
for 3.333cubic feet
just to know im useing a audiopipe sub in my build
i might use some Acry-Tech Acoust-X 1 inside the box if that would help
well let me know what ya'll think ?
Re: advice need on twin rad woofer build
That should be OK as long as there's enough room for the air to "move".   Bass wavelengths are really-long relative to the box-size so the shape isn't too critical.   At higher frequencies, square is the worst shape because the internal standing waves resonate at the same frequency in all dimensions.
I don't think that matters either...  If you had two active  woofers you'd want them moving in & out together even if one woofer was mounted on the back.  So, I assume a passive radiator is similar.
P.S.
Since you're building it yourself you might want to play around with WinISD to check the (predicted) performance with a larger box.    Often, the cabinet is smaller than optimum just for practical-space reasons.     And if you build it larger and it doesn't "sound right", you can always do something to reduce the internal volume.    Do you have the parameters for the passive radiator?   (The Dayton woofer parameters are usually available.)
